Old 04-29-2015, 11:18 AM   #1
WDH for HW277
Hey, any HW277 owners out there using a WDH? I purchased a BlueOx Sway Pro and it seems the a-frame design will not accommodate the clamp on lift brackets. Before I go drilling into the frame I wanted to see what others have done.
TIA,
Michael
msweetco is offline   Reply With Quote
Old 04-30-2015, 03:31 PM   #2
bikendan's Avatar
Personally, I think that WDH is overkill for pulling a popup.
Most popup owners use a Reese WDH specific for popups.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 04-30-2015, 07:12 PM   #3
vinmaker's Avatar
WDH really depends on the tongue weight. Many SUV's require them when the tongue is over 500 or 600lbs.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 04-30-2015, 07:22 PM   #4
I bought a 6000# Equalizer unit and can tell you I need to adjust to the minimum weight distribution to stay optimal. TV is a F-150 4x4.
Still like the sway control it provides none the less.
Could only get the trailer side brackets back to 31 inches due to frame cut outs and had to relocate emergency breakaway unit to do so.
TR
Tree Rat is offline   Reply With Quote
Old 04-30-2015, 07:32 PM   #5
RedLdr1's Avatar
The Ford Explorer, even with the OEM Tow Package, requires a WDH when the Tongue Weight (TW) is over 200 pounds. I'm at about 400 pounds TW so I am looking for a decent setup myself...
Wayne and Christine
2019 Sunseeker 2500TSF On Order Due "Off Line" on May 18th
2018 Ford Focus SEL Hatchback TOAD
RedLdr1 is offline   Reply With Quote
Old 05-01-2015, 11:24 AM   #6
We have a 2014 A122 (max gross 3100 lbs) towed by a 2008 Hyundai Entourage (minivan). Test driving at delivery in the dealer's lot showed a lot of bounce and porpoising for both vehicles. Dealer recommended and I accepted install of Equalizer 600/6000 WDH/anti-sway. Propane tank tray (dual tanks) had to be raised 2" to fit the brackets. Even then the brackets are slightly closer to the hitch than factory recommended - the reason for the heavier bars than tongue weight requires.
With the WDH, Entourage rides nearly the same with Aframe in tow as without - very comfortable road car. Wife is even willing to drive towing - handling is really that good, even at 75 MPH. She drove I-80 through Nebraska in 30MPH crosswinds at 65 MPH without complaining - and I was able to catch up on sleep.
Before, we had a 2000 Coleman Westlake PUP behind a 1993 Ford Explorer, no WDH. The PUP would go into sway anytime I got over 62 MPH. Taking the PUP from San Francisco to Lake Tahoe (or on to Colorado) was always a white knuckle experience.
If you have a 300lb + tongue weight, especially on a soft suspension TV, you will be thankful that you spent the money on a good WDH. Anti-sway is always welcome. Wife looks forward to weekend camping trips because we have fun, and no white knuckle moments. WDH - I don't tow without it anymore!
Fred W
camping Colorado, Nebraska, Wyoming one long weekend at a time - hope to add Utah and New Mexico in the next year.
Old 05-01-2015, 12:11 PM   #7
RedLdr1's Avatar
Typo correction! A WDH is required at weights over 350 pounds, not 200, as erroneously stated above.... FYI, Electronic Sway Control is part of the Tow Package...
Wayne and Christine
Old 05-01-2015, 10:22 PM   #8
Fords electronic sway control provides limited sway control by modulating the brakes like the traction control. Does not replace a good mechanical sway control device.
TR
Old 05-02-2015, 07:14 AM   #9
HONDAMAN174's Avatar
If the vehicles anti sway control is active or in use, you are already half way to trouble. get an sway bar installed- save your white knuckles for the 12oz cold ones.
Just glad to get away
Old 05-02-2015, 09:09 AM   #10
Blog: RVroadtripper.com
hbillsmith's Avatar
I used an Andersen WDH. Found it much lighter and much easier to put on and take off. Check out their YouTube videos to learn more.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
