Old 08-11-2014, 04:48 PM   #1
Dr. Doofenshmirtz's Avatar
What is this switch?
Just got back from my first trip with our new pop-up (Forest River Rockwood 1910). One thing is bothering me though.
There's an on/off switch under one of the seats that I can't quite figure out what it does. When I picked it up from the dealer he didn't know either but I figured it would be easy enough to figure out once it was up... no such luck.
Forgot to take a picture of it but attached is the location from a photo I found online.
Any ideas?
Dr. Doofenshmirtz is offline   Reply With Quote
Old 08-11-2014, 05:01 PM   #2
Paradise has arrived!
Paradise115's Avatar
It looks like my awning control switch. Could it be for an option you didn't get? Strange the dealer didn't know. I'd call the service dept and ask them.
Paradise115 is offline   Reply With Quote
Old 08-11-2014, 05:03 PM   #3
oadago's Avatar
Hot water heater switch ?
oadago is offline   Reply With Quote
Old 08-11-2014, 11:38 PM   #4
It's hard to tell without a better pic...could be the hot water heater switch if it has an indicator light...could be the water pump switch...What's under that seat?
It's not an awning switch, as all pups have manual bag awnings....
IonicBrick is offline   Reply With Quote
Old 08-12-2014, 08:33 AM   #5
f5moab's Avatar
If not marked, is the converter under the cushion? If so, just follow the wire back to the fuse panel. On mine there are two switches at that location, water heater and water pump.
f5moab is offline   Reply With Quote
Old 08-12-2014, 04:31 PM   #6
phillip252's Avatar
Is your camper equipped with a fresh water tank? If so that could be the swicth for you fresh water pump, I have a Rockwood 1970 and that is where my switch is located.
phillip252 is offline   Reply With Quote
Old 08-12-2014, 04:46 PM   #7
Thanks for the ideas... I'll do some more investigating and let you know what I find.
Old 08-12-2014, 08:15 PM   #8
Now a "Top Member"
EdJunior's Avatar
My guess is the water heater switch. In a lot of the smaller RV's, that's a popular spot for the water heater. The water pump would be the other answer, but you would hear that right away if you turned it on, provided the fresh water tank was full.
Ed and Sharon
2010 Wildcat 28RKBS
2011 Ford F-250 XLT, 6.7L PSD
Ride-Rite Airbags and Airlift wireless remote compressor...nice!
Old 08-23-2014, 10:15 PM   #9
I ran into the same thing. Mine will shut off the water pump. Try running your water at sink...tank side, and flip the switch to see if it shuts off. We were camping and the water tank went empty while running the tap water and the pump wouldn't shut off, that's when I discovered what it shuts off.
ESDSKeith is offline   Reply With Quote
Old 04-27-2015, 02:13 PM   #10
It your water pump. On mine I shut off when towing and storing. I ran out if water camping and the pump will jeep running, that switch will shut it off.
