Old 05-05-2016, 07:32 AM   #1
Which Camco insect screens fit new HW29SC?
We have a brand new Flagstaff HW29SC. It is currently parked by our barn. We have every kind of wasp in the barn. I would like to cover the vents with screens. Does anyone know which screens fit our popup?
Is there anything I can do to keep them out of the A/C unit?
What about the fridge vents?
I'm referring to these type of screens:
Amazon.com: Camco 42145 Flying Insect Screen - Model WH 500: Automotive
http://www.amazon.com/Camco-42141-Fl.../dp/B00192JFBI
Amazon.com: Camco 42150 Flying Insect Screen - WH 200: Automotive
Thanks!
Skier is offline   Reply With Quote
Old 05-05-2016, 07:56 AM   #2
there are many store bought screens, but very easy to make your own for the fridge vents and the water heater door vents, ....for fridge, cut the metal screen just slightly over size, as you press it into the opening, the cut edges will be small barbs that will hold forever,......for water heater door, cut to size and then run a bead of caulk around the vent area on the inside, press the metal screen into the wet caulk, can hold in place with tape, when dried you have a permanent fix, .... three years of trailering and never a problem with these two ideas............
ID:	106948   Click image for larger version
ID:	106949   Click image for larger version
fella10 is offline   Reply With Quote
« Noisy Winch | Roof »
