Old 03-29-2015, 09:12 AM   #21
Originally Posted by f5moab View Post
You also gain some more lift, that includes the axle, if you go to bigger tires. I gained, basically, another 1.5" of lift when I increased tire size by an overall diameter of 2.9 inches.
Stock tires: 175x80 13 24" Dia
Dealer installed larger tires: 205x75 14 26.1" Dia
My installed tires: 215x70 15 26.9" Dia
I left the tires alone, as my old setup would rub the wheel well and create a whole in it for water to leak in. I've not had any problem with axle clearance, but wanted bumper and wheel well clearance improvement.
steamboatscott is offline   Reply With Quote
Old 03-29-2015, 04:15 PM   #22
f5moab's Avatar
Strange, I have no rubbing problems with the 14" tires Mark installed at Roberts, nor the 15" I installed when living in Moab. (Went 15" so I could dump the trailer tires and go with a set of AT tires.}
Had one two many flats on those trailers tires and not from highway driving. The sidewalls split like crazy when pulling the trailer over ledges when dispersed camping around Moab. I have taken those Yokohamas down some serous road in the San Rafael Swell a few times and no problems, no flats.
Now, that's a place to go camping....if you want no want nearby. I can give you some GPS locations for some sites there that are GREAT and the sights are pretty good too.
f5moab is offline   Reply With Quote
