Originally Posted by bleurt
the design has changed for the better if you look back in the posts there are many post on lift problems. i had a horrible time cause of my lift system and replaced it, it cost me 420 dollars with the tax for new system. because if the motor stops working you only that little 7/16 nut on top of motor to turn it takes about 30 turns or more to raise 1 inch.
When you replaced it did you use the same winch or just buy a whole new one of the same?
I also like maybe taking it to a motor repair shop.....my problem is that the motor overheats (no resistance on the top though) and it pops the Short Stop relay, it cools and then will continue for a little more. The only problem is that little motor.
