Old 11-17-2014, 10:10 PM   #1
gail strom's Avatar
Winch to pop up top stopped working
It worked well before and for whatever reason it no longer does, pushing the button makes no sound at all. I had the camper plugged in and nothing... I even tried jumping the battery and nothing. Any ideas?
gail strom is offline   Reply With Quote
Old 11-17-2014, 10:40 PM   #2
GalsofEscape's Avatar
There may be a fuse in the winch. Do you know the make and model of the winch?
HTT: "EscapeII" 2016 Shamrock 23WS (current)
PUP: "Escape" 2010 Rockwood HW 277 (gone)
TV: "Bruce" 2011 Dodge Durango V8 Hemi Crew
Just us gals (me, Sis and our daughters)
We spend alot of money to go sit in the woods
GalsofEscape is offline   Reply With Quote
Old 11-17-2014, 11:05 PM   #3
maccve's Avatar
Check the fuses...on mine, if the battery gets too low, then a certain fuse always blows and the battery will not charge leaving a dead winch. I solve this with a pair of jumper cables that I always have with me.
If the battery has charge, then it could be a fuse/circuit breaker thing that is down underneath the frame in some.
If that doesn't work, then not sure...mine has a cutoff switch that turns it off so it does not overheat, but I usually just let it sit a few seconds and it works again. If it is broken, it could be the problem.
Mac's FJ
maccve is offline   Reply With Quote
Old 11-18-2014, 10:04 AM   #4
I have a 2007 flagstaff 227 popup. And when I first bought it there were times that I would have to manually turn the shaft with the override nut and then the motor would start working again. It the lower setting on the motor is not set properly and it goes too far down then it might just need the couple of turns on the nut to start it again. When it acted this way it seemed as if there was no power going to the unit. I recently replaced the motor on my trailer because it was under powered for the roof and the a/c unit. Good luck.
Vicfut is offline   Reply With Quote
Old 11-18-2014, 02:38 PM   #5
f5moab's Avatar
Some great info on how to troubleshoot the motor system...
Wicked Winch - Lift System Troubleshooting for Flagstaff Camping Trailers | Roberts Sales
f5moab is offline   Reply With Quote
Old 11-18-2014, 02:44 PM   #6
raspivey's Avatar
I had a wire that kept coming loose on my last trailer. Pull the housing apart and check the connections at the switch.
Old 11-23-2014, 06:59 PM   #7
vinmaker's Avatar
Definitely check the wiring. that is usually the problem. You probably just have a short someplace.
Good luck.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 11-28-2014, 01:17 PM   #8
I have 2007 rockwood freedom popup and the electric lift will only lower the roof once I have manually raised the roof. The motor will not make any sound when trying to raise it. I had to manually raise the roof on the last camping trip and it took a lot of rotation with a ratchet. I have not found any blown fuses.
ranger1 is offline   Reply With Quote
Old 11-28-2014, 02:44 PM   #9
f5moab's Avatar
Far from an expert, but if it lowers there no no problem with the fuse, but it sure sounds like the high limit se\witch. Refer to the link to Roberts in my previous post. (And you can use a power drill to raise the roof, did it myself a few times.
Old 11-28-2014, 04:08 PM   #10
thanks
i'll check it out
pop up
