Old 11-01-2015, 04:18 PM   #1
flagst228's Avatar
Winterize a cassette toilet
When I got the camper new it looked like there was pink antifreeze in the flush side of the toilet. Do u just empty the water through the clear tube and run the flush button till the water stops or should I use a little antifreeze to run through it in the fill tube... Thanks
flagst228 is offline   Reply With Quote
Old 11-02-2015, 04:08 AM   #2
Drain and run it dry.........then add RV antifreeze......run pump until you see pink.
Trevor43 is offline   Reply With Quote
Old 11-02-2015, 04:22 AM   #3
flagst228's Avatar
Thanks for the info, wasn't sure if antifreeze would have hurt the pump
Old 11-02-2015, 10:15 AM   #4
If it's a cassette, could a person just take it out and store it inside? We store our porta potti in the basement during the winter.
61cubby is offline   Reply With Quote
Old 11-02-2015, 10:18 AM   #5
flagst228's Avatar
The cassette you can leave in where it belongs, it's empty anyway. I was asking about the flush side of the toilet
winter, winterize
