Old 10-15-2015, 05:40 PM   #1
Winterizing a HW296
Any videos on how to do this? Or all the tools to do it?
lakecumberland is offline   Reply With Quote
Old 10-15-2015, 10:36 PM   #2
Look in the community forums under FQA
kinma13 is offline   Reply With Quote
Old 10-16-2015, 07:50 PM   #3
That didn't help any. Anyone else got anything?
Old 10-16-2015, 08:42 PM   #4
Try youtube no videos on a hw296 but winterizing is the same as on a TT other then a faucet or 2. What are you looking for?
Old 10-25-2015, 01:38 PM   #5
T. Shawn
I've got a HW 25S which I need to winterize. Seems pretty straightforward, but I'm not sure about how the water heater works, bypass valves, etc. This is our first year with the camper and the instructions we have seem to be light on the details. Do I need to pump the antifreeze in or do I have a water pump? I'm assuming I don't have a pump and will need to do it manually.
tshawn is offline   Reply With Quote
Old 10-25-2015, 01:41 PM   #6
I'm doing ours next weekend. YouTube is where I learned the most information.
Old 10-25-2015, 01:44 PM   #7
Ford Idaho's Avatar
That is mine, I do not know if your unit has a like system but it may.
Water heater by pass valves are on the backside of the WH look to the inside of yours to locate them, under a seat or bed or in a cabinet.
Old 10-25-2015, 03:47 PM   #8
tshawn here's a pic of the bypass valve
Old 10-25-2015, 03:50 PM   #9
tshawn you can pump antifreeze in from the hose connection or you could install a winterizing valve (but it's alot of work up front but will be very easy every year from now on) and you winterize the water pump.
ID:	92816   Click image for larger version
ID:	92817   Click image for larger version
Old 10-25-2015, 03:52 PM   #10
First pic is the winterizing valve between the pump and the water strainer
winter, winterize
