09-21-2011, 11:54 AM
Winterizing Rockwood HW256
Hey everyone, I am new to the forum, not new to camping, but new to winterizing. I've printed out some very detailed instructions, but some things still need clarification...
1. Once I bypass and drain the hot water heater by engaging the release valve and removing the anode rod, is it necessary to get every last drop of water out of the tank?
2. Once drained, do I reinstall the anode rod or leave the hole open during winter storage?
3. When draining the fresh water tank and then filling with anti freeze, is it necessary to run the water pump until all anti freeze has left the fresh water tank or leave it run until each faucet begins pouring with pink liquid and then close faucets and turn off pump?
4. Should any anti freeze remain in the fresh water tank or should the remaining liquid be drained as well?
5. Is it necessary to pour antifreeze into the cassette potty or just the freah water line used for flushing?
Thanks in advance for your help everyone. If done correctly, this will save me a lot of time, two trips to the RV dealer and $100!
Thanks,
Cory
09-21-2011, 03:13 PM
too fast turbo sled
DO NOT POUR ANTIFREEZE IS FRESH TANK!
purchase the kit to be able to do it from the suction side of pump.
Put anode back in
remove water filter before winterizing.
bypass hw heater and get all that u can.
Open low point drains and fresh water drain.
run all taps including inside and outside shower as well as toilet till all is pink.
Dump leftover antifreeze down traps and leave a little antifreeze in toilet.
2005 silverado 2500hd pro ride 5th
2011 palomino sabre 32 bhok-6
2012 arctic cat f1100 turbo limited edition sno-pro
Ron and Amy Benhart
2012 nights camped (5)
09-21-2011, 03:34 PM
Be sure to check the detailed instructions for toilet. I've got to re-read mine and figure out how to ensure I get all the water out of the toilet fresh water tank (It's a Thetford Cassette, flush water comes from a separate tank, not the main fresh water tank).
I mention this since I believe my Thetford manual specifically said to never leave water in the bowl to prevent damage to seals at the flush valve.
 Jeep4Two
2011 FR Rockwood Premiere A126 Hard Side
TV=2011 Jeep Wrangler Sahara 2 Dr
Reese 66065 WDH, Curt WDH Shank #17120
Prodigy P2 Brake Controller, Mopar 7-pin Harness
B&M Transmission Cooler (#70268)
09-21-2011, 03:38 PM
too fast turbo sled
Someone will have an answer regarding that style of toilet.
Ron and Amy Benhart
09-21-2011, 09:01 PM
Here is the link form the 402C that came in my A126. Winterization looks simple, but potentially unpleasant as the annual cleaning is part of the winterization of the holding cassette.
http://www.thetford.com/LinkClick.as...d=569&mid=1470
The key is also draining the flush water holding tank and fill tube. I don't see why the cassette couldn't be stored in a garage since it's removable.
 Jeep4Two
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 579 |
| 116 members and 463 guests |
| 2011sv264, 2lvrvn, 4bnabird, 4Jeeperz, Adony, adp1326, armcor02, ayotte, Bigmatt, bikeman911, bikendan, bka4tcu, bmcgee, bob213, Bob_Loblaw, boubou, Buffalohunter, bush, buzzmonster, Cccross3, cgreen1509, chevy02, cllecr, COcamper, crawford, cyclepuck, dashonthedash, dasimser, daw592, DDC, ddemme, DeeMax, dezolen, DonG, donn, Drmstx62, Dutch & Di, fast murray, Fire Instructor, forensicdeac, FreedomTracker, gimp425, GlacierGus, greran, grhodes50, h20ski, Hilgy, hjmiberry, House97, Hydrothunder, Iggy, itat, Itsthetwoofus, J McClure, J R, JamesR, jasni, jimandjoyhamel, jjhwisconsin, JJL, jking, johnthecamper, jsutherl, jtstromsburg, KRS, kwjeepxj, Mad4sax, manvel, Margaret, Marsh707, meatguy, michel, MikeT, Mnflyboy, mwilson949, ncgrl1, NO3putt, nowait, ohiobill, partime, patov6, Pawpod, peaeye, pg_rider, Phil1, Phil57, PHS79, punkaccountant, rgfenner, RJHuser, rkswyo, rmason8092, RockyMtnHigh, Rsgtivr6, sbond, Sg6923, SinkorSwim, Smithee, snackage, sprayking, Stedman1, steeleshark2, sundawg, Swinks, tentcamper1, Terier, thehamguy1, thom01, Tincup13, troyt, tsmcmillen, VinceU, vp22er, Waterfowlwarrior, WestCoastRV'er, Westernflyer |
| Most users ever online was 1,025, Today at 01:04 PM. |
