Old 12-05-2018, 10:49 PM   #11
Simple answer ... no.
If you need to winterize at those temps then I would need to winterize living in central Florida..
2016 Siverback 33IK
Old 12-05-2018, 10:55 PM   #12
Detourkid's Avatar
Originally Posted by swampdonkey772 View Post
Why would you winterize if it never gets to freezing or below. And if it does it will only be for a few hrs. I would drain the tanks just because i wouldn't want it to start getting moldy. But to fully winterize is a waste. I'm in central valley California trailer stored outside. I've never winterized even if it gets below freezing at night. It doesn't stay cold enough long enough to worry about it
Thank you
Detourkid is offline   Reply With Quote
Old 12-05-2018, 10:55 PM   #13
Detourkid's Avatar
Thank you everyone..
2007 Rockwood pup #2280
Toyota FJ Cruiser
Ok can we go camping now..
Old 12-05-2018, 11:14 PM   #14
Detourkid's Avatar
Originally Posted by debit View Post
As a lot of people have written, I'd drain the tanks. It is always usefull to clean out the hot water tank each year. I also park my RV inside, but I use an oil filled heater during cold spells (like tonight). I also cut a hole in the panel next to the water pump to let warm inside air circulate around the pump.
Ram 2500 diesel/Surveyor 251rks
I leave the cabinet doors open to let air flow in around the pump.. going to drain all fluids and open low spot valves .. just so I know whats in the tanks
Old 12-06-2018, 03:33 PM   #15
gastan's Avatar
I live in St Helens. (Just north of Portland and along the river for you out of state-ers)
The TT stays outside along side the garage all year long. For winter I drain the water heater, pull the water pump, remove the water filter, and make sure all tanks are empty. I keep a heater in it set to about 40-45 degrees. Have never had any problems. Ever.
2012 Rockwood MiniLite 2104
gastan is offline   Reply With Quote
Old 12-06-2018, 04:16 PM   #16
2thdr's Avatar
Originally Posted by 2thdr View Post
".. it never gets below 45 ..50 degrees.."
Last time I checked water freezes at 32 degrees. Why on earth would you if what you say is true?
This is one of those, "I should have read it before I sent it..".
Sorry for the snarky comment.
2019 FR Cherokee Wolf Pack 24pack14+
2019 Ford F250SD 4 x 4, 6.2L
2015 DL1000A ADV
2014 CRF250L
2017 FZ-09
2thdr is offline   Reply With Quote
Old 12-06-2018, 04:46 PM   #17
Mad Cow's Avatar
If it was my garage it would be fine. Mine is heated.
Mad Cow is offline   Reply With Quote
Old 12-06-2018, 05:51 PM   #18
Detourkid's Avatar
No worries.. appreciate everyone's thoughts qnd comments
winter, winterize
