Old 12-05-2018, 09:27 PM   #1
Detourkid's Avatar
Would you still winterize if pup stays in garage
I have a 2007 Rockwood Freedom model 2280 tent trailer..
I have it in the garage thats built into the house.. it never gets below 45 ..50 degrees..
I just got back from hunting with it and plan on camping in March or asap..
So Would You Winterize It .?
White water tank has water in it ..
Havent used hot water heater but bet it has water in it ..
Cassette type toilet has water in it but black tank is empty and clean..
Detourkid is offline   Reply With Quote
Old 12-05-2018, 09:35 PM   #2
heavynlori's Avatar
We winterize our power washer and garden sprayer that are kept in our attached finished garage here in NW Ohio just to be safe
heavynlori is offline   Reply With Quote
Old 12-05-2018, 09:36 PM   #3
2018 Dynaquest 38TS
I would just drain the water heater and open the low point drains. you should be good. if you get a cold snap you could always put a heater in it.
DR Quest is offline   Reply With Quote
Old 12-05-2018, 09:55 PM   #4
In case your power goes off an ounce of prevention could save a lot of headaches
Beck is offline   Reply With Quote
Old 12-05-2018, 09:57 PM   #5
bikendan's Avatar
Since you live West of the Cascades and near Portland, I think you'll be fine. But I would drain the WH, FW tank, low point drains and blow out the water lines.
Equalizer WDH
Old 12-05-2018, 10:01 PM   #6
camper-mike's Avatar
If you are done using it for the season why not winterize and not have to wonder or worry.
camper-mike is offline   Reply With Quote
Old 12-05-2018, 10:03 PM   #7
Detourkid's Avatar
Ok Thanks gang.. all great ideas.
2007 Rockwood pup #2280
Toyota FJ Cruiser
Ok can we go camping now..
Old 12-05-2018, 10:12 PM   #8
Why would you winterize if it never gets to freezing or below. And if it does it will only be for a few hrs. I would drain the tanks just because i wouldn't want it to start getting moldy. But to fully winterize is a waste. I'm in central valley California trailer stored outside. I've never winterized even if it gets below freezing at night. It doesn't stay cold enough long enough to worry about it
swampdonkey772 is offline   Reply With Quote
Old 12-05-2018, 10:15 PM   #9
2thdr's Avatar
".. it never gets below 45 ..50 degrees.."
Last time I checked water freezes at 32 degrees. Why on earth would you if what you say is true?
2019 FR Cherokee Wolf Pack 24pack14+
2019 Ford F250SD 4 x 4, 6.2L
2015 DL1000A ADV
2014 CRF250L
2017 FZ-09
2thdr is offline   Reply With Quote
Old 12-05-2018, 10:46 PM   #10
As a lot of people have written, I'd drain the tanks. It is always usefull to clean out the hot water tank each year. I also park my RV inside, but I use an oil filled heater during cold spells (like tonight). I also cut a hole in the panel next to the water pump to let warm inside air circulate around the pump.
Ram 2500 diesel/Surveyor 251rks
debit is offline   Reply With Quote
winter, winterize
