Old 01-31-2016, 02:36 AM   #1
X Chock?
Anyone use these on a HW296? If so do you use 2 or just one? How well they work?
lakecumberland is offline   Reply With Quote
Old 02-07-2016, 07:15 AM   #2
We have a 2016 hw296 and use 2 x choke on our trips. Really stabilizes the pup better than when we used just one. My DH is like a bull in a China shop. Need all the stabilization I can get.
2016 HW296
2016 Ford F-150
tigger68 is offline   Reply With Quote
Old 02-07-2016, 09:14 AM   #3
Do they fit ok?
Old 02-07-2016, 09:27 AM   #4
Lakecumberland, I don't have your rv but I use 2 x-chocks with out TH which sits pretty high (three steps entry) and they take about 95% of the shake out front to back. much better than when I was just using ground chocks. I think you will be very pleased with them.
Come on SPRING! HAPPY RVING!
hdmtnrider is offline   Reply With Quote
Old 02-07-2016, 10:18 AM   #5
Yes these fit the 296 just fine. But I believe they may come in 2 sizes which a didn't know when a bought them. I don't know what size we purchased. Sorry
2016 HW296
2016 Ford F-150
Old 02-08-2016, 06:31 AM   #6
Take a look at Bal XChock P/N: 28005.
Old 02-08-2016, 10:44 AM   #7
I know we have bal xchock's
2016 HW296
2016 Ford F-150
Old 03-05-2016, 02:31 PM   #8
X-chocks Get Loose when Leveling Trailer
We have used X-chocks on the last 2 trailers, and been pleased. I get them tight to hold trailer in place before un-hitching. However, I stopped using them on current trailer because, even when I get them very tight, after the LCI Ground Control 3 (6 point) leveling system completes leveling the trailer... the X-chocks are VERY loose. I fear that if I tighten up after leveling they will be so tight when levelers go up, to leave, that I can't get them loose. I also fear that with much slope that the trailer may roll as the trailer is being leveled. Does anyone else have this issue?
PapaE is offline   Reply With Quote
Old 03-05-2016, 03:42 PM   #9
Uncertain what to get to use.
Old 03-05-2016, 04:13 PM   #10
Ford Idaho's Avatar
Are the tires off the ground or have very little contact with the ground?
Old 03-05-2016, 04:29 PM   #11
If they are really Bal X Chocks, you should be able to loosen them regardless with the ratchet wrench furnished with them. When the trailer is leveled, it is releasing pressure on the suspension and the axles move apart slightly especially if it has torsion axles. Not so much on spring suspended axles.
Old 03-07-2016, 12:43 AM   #12
They are all on the ground. If it lifts them any, it is not much. It appears to flex the suspension and make the tires just a little further apart... does not take but a small amount to make the X-chock loose
Old 03-07-2016, 12:46 AM   #13
We have springs... It appears to flex the suspension and make the tires just a little further apart... does not take but a small amount to make the X-chock loose
