Old 08-11-2013, 03:59 PM   #1
markb5900's Avatar
Wireless Fence
Has anyone used the wireless fence in their trailer?
We have it at home and it does a good job of keeping the pup in her yard.
Should add, we do plan on keeping her on a leash, but thought about taking the "fence" with us in case she decides to dart out the door or got loose somehow.
Mark B
2015 32 Foot Rockwood 8289WS 5th Wheel
2017 GMC 3/4 Ton TV
markb5900 is offline   Reply With Quote
Old 08-11-2013, 04:55 PM   #2
Triguy's Avatar
I would need to try it. As I recall, the dog needs to be taught the boundaries visually as well as through the collar, which is something to consider for your particular dog.
There are portable systems you can use that use a radius that might work for campsites. I think this could possibly work at a site you stay at consistently (like a permanent spot). It might be doable for a spot you have long enough for the dog to get used to the boundary.
I wonder what effect this would have on the dog when you get home after multiple trips?
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 08-11-2013, 04:59 PM   #3
markb5900's Avatar
We had to "train" her with the flags when we first got the system and I think she got zapped a total of two times before she quit going near them.
Now, if the collar starts to beep, she turns and goes the other way.
That is why I was thinking that it might work in the camper also, hopefully she would always be on her leash/tie out, but would like some type of emergency STOP for her since she only listens when she decides it might benefit her. LOL
Mark B
2017 GMC 3/4 Ton TV
Old 08-12-2013, 08:15 PM   #4
Oaklevel's Avatar
I know nothing about the invisable fences but wouldn't it get alot of interference using it with / in a metal trailer ???
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 08-12-2013, 09:55 PM   #5
kz08h5's Avatar
I thought about getting a wireless fence for our dogs. I decided not to do it as the area of containment is a circle. This would cause a problem in most of the camp sites I have stayed in. When you make the pattern big enough for the dogs to get around the end of the RV the dogs will be able to go to the RVs on either side. It's been over 3 years since I checked these out so there may be some pattern adjustable systems out there that could create a rectangular containment area.
I would try a wire system where you put the wire in something like a garden hose so the dog can see it. Then you can line the camp site with it.
kz08h5
2008 Chevy Silverado 2500 Duramax Crewcab
Jeep Commander - sold
Flagstaff V-Lite WRB26
kz08h5 is offline   Reply With Quote
Old 08-12-2013, 10:55 PM   #6
Grizzlygibbs's Avatar
I have a Tri-Tronics Basic G3 electronic dog training system. When my dog does something I do not want him to I use a warning tone/beep. If he continues, he gets a low shock. If he continues yet again or more, he gets a bigger zap. The only time he is on a leash is when we are in a very populated area. It acts as an invisible leash. When people tell me I need to leash my dog I tell them if he is a problem I will be the first to leash him. He actually behaves better without a leash since he is so good with the dog training collar.
2008 Toyota Tundra Crewmax Limited w/tow mirrors, 5.7L, 4.30 gears, six speed tranny, towing package, Firestone Ride Rite airbags.
2014 Rockwood Roo 233s, PI HW30-C, Equalizer 10k 4 way hitch,
Grizzlygibbs is offline   Reply With Quote
Old 08-12-2013, 11:58 PM   #7
2SGMRET's Avatar
We had the invisible fence brand professionally installed at our home three years ago. We have a portable rock that I add wire to around our campsite. When it's a new campsite we place the invisible fence flags around the site as well as the wire. We then walk our two labs around the perimeter to show them the limits and we have never had any issues with them leaving. We have used it at least in 10 different campsites. The flags also let others know you have an invisible fence. When we take them for a walk we take off their e-collar, always exit and enter at the same location on the wire, and place an entry mat over the wire. It is shocking how quick they learn the system. Strongly recommend.
2SGMRET is offline   Reply With Quote
Old 08-14-2013, 10:18 PM   #8
Anacortesians
We had Invisible Fence at our home in Everett a few years back. It worked great. Our present home has a fully-fenced back back-yard, so IF isn't needed.
I think the cable needs to be buried, but maybe one that was encased in a clearly visible hose would work in the campground environment. You'd probably need to get the dog trained to recognise the boundaries. At Everett, we had a second system that kept the dogs out of the formal living and dining areas. It was mounted on the floor joists under the house.
Frank and Eileen
No longer RVers or FR owners
Old 08-16-2013, 06:51 AM   #9
kz08h5's Avatar
Markb5900, I just saw an ad yesterday from Tractor Supply that had a Petsafe wireless unit that stated the containment area can be customized. I didn't read the set up manual, but it can be read on line. If it can be truly customized the only question then becomes how easy is it to customized the area for each camp site.
kz08h5
Old 08-23-2013, 01:13 PM   #10
fields's Avatar
I tried to use my wireless petsafe fence at our campsite once. It wouldn't work with the receiver inside the camper. I moved the receiver outside the camper and the dog would get shocked if he went inside the camper. You have to plug the receiver outside and take the dog's collar off when he wants to go in. The metal on the camper interferes with the signal.
fields is offline   Reply With Quote
