Old 12-07-2016, 10:58 PM   #1
Sparks Full Timers's Avatar
100lb Propane Tank
I am adding a 100lb Propane tank to my system ( 2016 Columbus 381 FL) has anyone done this and can tell me how and where you hooked it up at. Everything I have tried ends up with needing another fitting that no place local seems to have in stock. Thanks for your help.
Sparks Full Timers is offline   Reply With Quote
Old 12-08-2016, 11:02 AM   #2
Head Rambler
Are you adding it to replace the existing cylinder(s), or in addition to them?
Did you buy the Extend-A-Stay kit or are you just trying to assemble the parts yourself?
Gotta go campin!
Old 12-08-2016, 07:48 PM   #3
No I did not, we ordered the tank from Home Depot and assumed the tanks valve and connection would be a typical QD Female like all the other 20 and 30 lb tanks in the RV world. I think I am close to plumbing into the regulator on the driver side and replacing a 20lb tank with the 100lb. Thanks for replying to my post.
Old 12-08-2016, 07:53 PM   #4
You will need to buy some connections. I have seen some people making it work.
2017 Leprechaun 311 FS
Jeep Patriot and Cherokee as toad.
Enjoying retirement.
jonwisconsin is online now   Reply With Quote
Old 12-08-2016, 09:03 PM   #5
lesptr's Avatar
By this to adapt the 100lb cylinder to the 20/30lb style connector.
https://www.amazon.com/gp/aw/d/B00TZ...wJL&ref=plSrch
And switch out one of your hoses to reach the 100 pounder.
https://www.amazon.com/gp/aw/d/B0019...236_SY340_QL65
I'm on my second camper and this works great.
2017 Coachman Chaparral 336TSIK
2015 F350 6.7
lesptr is offline   Reply With Quote
Old 12-08-2016, 09:16 PM   #6
Jack of All Trades
RJHuser's Avatar
This is what I used to connect a 100 lb. tank to my 5er.
https://www.amazon.com/Marshall-Exce...keywords=Me422
This connects to one of your existing propane tanks, and the pigtail from that tank connects to the other end. There is then the port to connect this:
https://www.amazon.com/Marshall-Exce...words=Mer40160
To connect from the above "tee" to the outboard tank.
Worked well for me last year. It allows you to use your existing tanks and the outboard tank at the same time (in my case, giving me 160 lb capacity (2 - 30 lb 5er tanks and the 100 lb outboard tank)).
Rick
Rick & Debbie; Brandy Schnoodle & Bucky (Dexter & Fritz R.I.P.) the Doxie "Kids"
2015 Jayco Pinnacle 36RSQS 5'er
2018 GMC Sierra Denali 3500HD, 6.6L Diesel Dually; B&W Companion 5'er hitch
ScanGauge, TST 507 TPMS
RJHuser is offline   Reply With Quote
Old 12-11-2016, 08:14 PM   #7
Thanks for all the help, finally got the right parts everyone sent and it worked, my wife appreciated it with the recent cold temps thanks.
Old 12-14-2016, 09:56 AM   #8
Head Rambler
Glad you got it figured out.
Can you post a list of the parts you used to get it to work for you? It would be a great help to people in the future.
Gotta go campin!
Old 12-14-2016, 10:10 AM   #9
Hi Sparks Full Timers,
One thing you might want to check before traveling with a tank that size, is the regulations at any tunnel you may be traveling through. Every tunnel seems to be different. They don't mind the "normal" size tanks as long as they are turned off.
I guess also, that if you are hiding it in the basement, then they won't know unless you are pulled over.
Good luck,
Don
Don and Michele
3 Adult Children - 4 Granddaughters
Present campsite - future homesitehttps://i246.photobucket.com/albums/gg119/dmdrj5/lake/dividingcreekviewfromhouselocation.jpg?t=120311985  4
dmdrj5 is offline   Reply With Quote
propane, tank
