12-31-2017, 04:05 PM
#21
Originally Posted by Arctic Wolf
My 69 BSA motorcycle is positive "Earth"
As was my 1965 Matchless G15-CS.
12-31-2017, 04:19 PM
#22
Originally Posted by llr
Good habit to do negative 1st, then there is no danger of wrench contacting ground, more revelent on cars with more metal around. Always be sure the wrench can't reach both terminals at the same time
2X be safe
12-31-2017, 04:30 PM
#23
Recently new!
Negative first, unless positive grounded. No campers in at least 50 years in the US have been positive ground. Like other posters have said, neg first. if the wrench slips and shorts to the metal casing, no harm.
That said, just be extra careful not to get the wrench across the terminals!
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14 lotsa mods!
2001 Ford F-250 7.3
Loving wife, R.I.P., 6/6/19
and Mason the always dirty dog! R.I.P, 2/19
12-31-2017, 05:04 PM
#24
Bene Gesserit Rule
Originally Posted by checkmate99
For such a simple task, this is beginning to sound like rocket science!
Wow, now we all know that it is rocket science. And I thought you were all just being a bit negative.
12-31-2017, 05:05 PM
#25
Bene Gesserit Rule
Originally Posted by aircommuter
Actually positive ground was used up through the late sixties on British cars and US trucks White trucks for one.
Why were they pos. grd in the first place? Answer in the old days most insulation was cotton braid, and with moisture or fog same thing leakage would occur where wires passed close to metal and at that juncture corrosion would occur, positive ground prevented this. So what made the big switch to neg. grd. When transistors came along the electronics industry settled on the NPN transistor which required negative ground. With that invention and plastic insulation was available too. Sorry if you don’t care just thought you might be interested.
I also have been a auto tech for over fifty years and one of my hobbies is restoration of tube type radios and juke boxes. Some juke boxes are seen in my home shop picture on the mezzanine.
That's your home shop. Again WOW!!!. Now I am starting to fell inadequate.
12-31-2017, 05:07 PM
#26
Bene Gesserit Rule
Yes, +ve grnd but those bikes were built before transistors, probably before valves too.
12-31-2017, 05:12 PM
#27
But they were so good at leaking oil, vibrating parts off, and exhibiting metal fatigue, not to mention sucking sand through the air "filter" leaving one on a 750 cc bike with the throttle stuck wide open while groping for the fuel turnoff 'cause the kill switch wasn't working...
12-31-2017, 07:00 PM
#28
Battery disconnect
Be sure and flip the battery disconnect switch off if you have one
12-31-2017, 07:14 PM
#29
Negative off First and on last for the stated reason of possibly arcing the wrench.
2016 Dynamax Isata 3 24FW
2016 Jeep Willys JK
Yellow Lab Buddy Biscuit Eater
USN-RET/DOD-RET
12-31-2017, 07:35 PM
#30
aircommuter’s shop
Holy crap!!! I am jealous. Not only of the shop, but of your ability to keep it so neat and clean.
I’ve got a 2 1/2 car garage. I can’t get a car in it and can barely walk through it.
2017 Rockwood 2703WS - Sold
2015 Keystone Sprinter 333FWFLS
2017 F250, 6.2 Gas, 3.73 Axle, 2902 lb Payload
If women don't find you handsome, at least they should find you handy!
12-31-2017, 09:17 PM
#31
Actually that is just one side of the shop, I don’t want to bore with other side.
01-01-2018, 08:47 AM
#32
Bene Gesserit Rule
Now you're just bragging.
01-01-2018, 09:13 AM
#33
Actually I’m just proud. I worked for I built i myself and I didn’t inherit anything.
Sorry. My son was going to inherit it though, be he left this world in February.
01-01-2018, 12:19 PM
#34
sorry for your loss. Very nice shop I have built several home on my own and understand the pride of accomplishment and ownership.
Tim
01-01-2018, 01:39 PM
#35
Hey Guys;
Thanks for the input and the humor. It is appreciated. Not really good with this electrical stuff. The DW and I did indeed wrestle those batteries out of the 5R yesterday. No easy feat, being that they each weigh 64 pounds. Just in a bad position to lift. In fact we could not lift them out with the purchased battery strap. Just bent over in an impossible position. I finally placed a web strap around the battery strap and was able to find a support bar, threw the web strap over the bar and hauled them up and out.
They are 4.5 years old and I am replacing them this week with Trojan T-105s. I have never removed them from the 5R in these many years. It is stored outside in a yard. I live at elevation in Arizona so winter nights are usually below freezing and summer days well into the low 90’s. I feel they have given me good service. I want to start removing them, especially during the winter so I will figure out a way to make this easier.
Here is my next question:
The Positive and negative battery cables are 6 guage. When my dealer changed from a single 12 Volt to dual six’s the jumper wire he used what looks to be about 12 guage to me. (no marking on the wire and cheap terminal lugs) One of the terminals is also corroded on that wire. So wouldn’t it be a good idea to get a 6 guage jumper wire?
Thank for all your help.
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
01-01-2018, 01:58 PM
#36
It's not a bad idea to get a better jumper between the batteries, however it's not a big deal either. Battery guage to use depends mainly on voltage drop and heat disapation. Short wire will have very little drop and I assume it is in free air space between the batteries. This assumes it is large enough to not act as a fuse or getting hot to the touch
2024 Artic Wolf 3018 Suite 5th Wheel
Prior TT Grand Design 2800BH TT 2021 - sold 4/24
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW Lariat Ultimate
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload - sold 4/24
01-01-2018, 02:09 PM
#37
Wrench Turnin Fool
I've always read that the jumper should be there same size as the cabling away from the batteries
Not all who wander are lost...
But I usually am
2001 Coleman SantaFe pop up
Excited new owner of 2018 Arctic Wolf 315TBH8
Towing with a 2005 F-250 5.4 GASSER
01-01-2018, 02:50 PM
#38
This is one of those things where size does matter, I prefer the weak link to be a fuse or breaker. I would change it out .
01-01-2018, 02:52 PM
#39
Wrench Turnin Fool
I would have to agree with aircommuter on this
But I usually am
01-01-2018, 03:09 PM
#40
Heaver Cable
Well I don't know if it is hot to the touch, but these cables are cheap enough and it is a six foot run so I think I will just eliminate a possible future problem and order a new cable. I found a place on-line that looks to be an ok company that will build me a 72 inch 6 guage copper cable for $11.36. Cheap enough.
Thank again everyone. A Happy New Year to you all.
