Old 08-03-2010, 07:15 PM   #1
2008 Puma 27FQ Tire Changing Help
Hey guys, I have a flat tire on my 27FQ. I requested an Owners Manual from palominorv.com in May, but never received the manual. Now I am not sure where to place my jack under the trailer, so I can change the tire.
Luckily, it went flat in the driveway, not somewhere on the road.
Can anyone with a same or similar model tell me what the manual recommends? There are also stickers on the trailer that say to torque the lug nuts in a star pattern to _________ ft/lbs, but there is no number in the blank, so I am not sure what torque to use when installing the new tire.
Your help is much appreciated.
Palomino Puma 27FQ
17 nights in 2010
So far 11 nights in 2011
chewbacca is offline   Reply With Quote
Old 08-03-2010, 07:25 PM   #2
I use the "E-Z-Jack and that is the second pic, all you do is back up on it with the good tire and it will raise the flat tire. I fell this is the safest way.
On the other hand some people do what is shown on the first pic with a bottle jack.
Old 08-03-2010, 08:10 PM   #3
Thanks for the info. I have floating axles, and they have a good deal of vertical travel, so I am not sure if the EZ jack will work. I may have to give that EZ jack a try though, and see if it will work.
Palomino Puma 27FQ
17 nights in 2010
Old 08-03-2010, 10:59 PM   #4
Iggy's Avatar
Rockwood06
Wanted to ask what trailer do you have? I have a 2011 8285WS 5th wheel and like the idea about the EZ-Jack.
Does it work on the new suspensions? I have this new suspension with rubber baby bumpers that twist. Not sure what they call is.
Iggy is online now   Reply With Quote
Old 08-04-2010, 07:30 PM   #5
Well,
I am going in to pick up a new tire and rim on Saturday. It is a slow leak, so I just keep hitting it with the compressor each day. Saturday I will change it out and take the tire in to see if it can be patched.
I have been telling the wife we needed a spare...now we will have one.
Palomino Puma 27FQ
17 nights in 2010
Old 08-06-2010, 09:23 AM   #6
Originally Posted by Iggy View Post
Rockwood06
Iggy, first off I am sorry for the late reply, these days it seems like the thread are just flying by and I can't keep up and the way I found this is because I went into my "user cp".
Now to answers your question: The camper I have is a 2006 Forest River Rockwood 8314ss and I have a torsion suspension, no leaf springs.
As far as your suspension I really don't know I have not looked at the new design.
So that you don"t spend $50 bucks on some thing you can't use, you can see if the E-Z jack will work by placing boards behine both back wheels approx 12" high and then back up on them just the rear wheels and then stop, then look to see if the front wheel were lifted off of the ground, if so then the E-Z jack should work. I believe that the thickest part of the E-Z jack is 12" high, I will know for sure by this week end, It's in my camper at our seasonal site at Hershey PA.
I have used mine once in 10 years and It works great. It takes up less space then all of that lumber and it is lite weight and you don't need to carry a bottle jack as well.
Old 08-06-2010, 02:55 PM   #7
I bought a "trailer aid" device which is basically a wedge you drive the good tire up on, lifting the bad one off the ground. I had picked up a screw in one tire and it had gone flat in the driveway. I pulled it up on the trailer aid, took the bad tire off to get fixed, put it back on, and then backed it off. Very easy and simple operation.
Hokiehall is offline   Reply With Quote
Old 08-08-2010, 09:19 PM   #8
So I was all set to position the bottle jack as Rockwood suggested, but I thought I would ask at the Puma dealer when I picked up the new tire & rim. The service tech said to position the jack on the axle, just behind the leaf spring. He made a point of mentioning that this would not bend the axle. I did as he said, and it worked like a charm.
Palomino Puma 27FQ
17 nights in 2010
Old 08-09-2010, 05:18 PM   #9
I suggested to use the E-Z-Jack, the device that is shown on the table. I had posted another pic that other members use as an example.
Old 08-10-2010, 08:26 PM   #10
Rockwood06, Sorry about the mis-quote, I appreciate the information.
I had the tire plugged & patched today. Now I have a spare. The cause was a nail. I dunno where I picked it up, but I am glad it started going flat in the driveway, not somewhere else.
Palomino Puma 27FQ
17 nights in 2010
palomino
