Old 07-22-2012, 11:25 AM   #1
Pullingpete's Avatar
2013 Puma 29KBH AC nt shuttng off when reaching temp set
Hello
Just wondering if anyone has had an issue with the AC unit not turning off when hitting desired temp set!
Pullingpete is offline   Reply With Quote
Old 07-22-2012, 02:05 PM   #2
jtstromsburg's Avatar
Is the thermostat set to auto or is the fan on low/high?
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 07-22-2012, 05:18 PM   #3
TURBS's Avatar
If thermostat is set to auto then compressor and fan will shut off at desired temp.
If set to "on" compressor will turn off at desired temp but fan will remain running till unit is switched to off.
Old 08-05-2012, 06:21 PM   #4
I figured it out. .. It was my guest setting the fan on HI instead of auto ... So the ac would shut off but the fan would stay running
Old 08-05-2012, 08:26 PM   #5
Glad to hear it was a simple fix!
Happy Campin !
Joel and Teresa
2016 Sabre 34TBOK
