Old 07-17-2018, 02:10 PM   #1
2015 36 qbok
I have a 2015 36 QBOK that has two black water tanks, is one for the back bathroom. My question is does the black water flush work on both tanks? Thanks for any information.
dougries is offline   Reply With Quote
Old 07-18-2018, 08:08 AM   #2
SeaDog's Avatar
Welcome to the forum is a great place to get your questions answered. Do you have two separate black tank dump valves? If so easy check is to hookup the flush and open one at a time and see if they flow water while flushing and you will have your answer. Let the forum know what you find out.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 07-18-2018, 08:37 AM   #3
Does not on mine. I'd like to add one to my rear tank but I'm ascared.
2015 Ram 3500 CC SRW SB 6.7 Cummins
2015 Sabre 36QBOK-7
Nights Camped, 2015: 23, 2016: 27, 2017: 29, 2018: 22, 2019: 20
mikeysotp is offline   Reply With Quote
Old 07-18-2018, 04:53 PM   #4
Fulltime family RVer
Did not on my 2013 either. I had one added (should have done it myself - $20 flush installed for $200 by a repair center!).
ependydad is online now   Reply With Quote
Old 07-18-2018, 07:36 PM   #5
Thanks for the info can you tell me how you had yours hooked up.
Old 07-19-2018, 12:19 AM   #6
I bought the tornado rinser or whatever it was called. I had the hose connection installed just beside the rear tank pull handles. I had the shop install it above the underbelly but below would have been just as fine.
Worked well for 6 years of ownership. I carried 2 of the black expandable hoses and a 4-way water manifold for the campground spigot/water source.
