Old 06-25-2018, 06:02 PM   #1
2018 386 fk
During the hot part of the day, I can not get the camper below 80. Slowly starts climbing from 72 to 80 without going in and out. Purchased unit in Feb. On our old camper we never had a problem keeping it cold. Any ideas?
ndthreet is offline   Reply With Quote
Old 06-25-2018, 07:25 PM   #2
RAMMIN_TIME's Avatar
We bought a brand new Puma 31BHSS in February and a/c didn’t work first trip. Does it sound like compressor kicking on?
RAMMIN_TIME is offline   Reply With Quote
Old 06-25-2018, 08:33 PM   #3
After the sun starts to go down, it will begin getting cooler. Around midnight it will pull the camper back to 72-74 and begin cycling. It will maintain 72 until around 10-11 am the next day. Then they both A/C's run continuously for the rest of the day.
Old 06-27-2018, 08:31 PM   #4
If you have a thermometer check the air at the return where the filter is and at the vent. There should be a 15 to 18 degree difference
bsmith001 is offline   Reply With Quote
Old 06-27-2018, 10:44 PM   #5
The air is cold, although the camper wont stay cool. We noticed today that there is significant "Gaps" around the bottom sides of the slides. We can see quite a bit of daylight. Is this normal? As we didn't see this in our other camper. All 5 slides you can see daylight around the bottom edges.
Old 07-03-2018, 09:49 PM   #6
Traveling Duo
Having the same issue with AC
I purchased my 386FK in October. Couldn’t keep it warm during the winter and can’t keep it below 80 during June. Hate to see what it will do during July. I was thinking about installing heat pumps and removing what should be Coleman ac’s but I believe are not Coleman’s. Has anyone tried two 15k heat pumps? Will it help?
Nealg is offline   Reply With Quote
