Originally Posted by mndmax
Hadn't thought about that. Thanks for the idea.
And technically you could open both rear gray valves and the front gray valve all at the same time and have 120 gallons of gray capacity
Before un-hooking slinky hose you'll have the raise it up in the middle to let both ends drain to the tanks then have some one shut all valves .
Only problem is you may have to have a bucket along for residual water in hose.
