Originally Posted by johndeerefarmer
They have moved the beams under the floor closer together as well as doubled up on the plywood decking. Also the walls are now R11 instead of R9. They also added an electronic door lock and went to Dometic quiet zone A/C's awhile back. The newer "modified" units also have
R11 in the walls instead of R9 which makes them 2" narrow than the older models. New units should be 98" wide instead of 100". I don't know exactly when they made the changes to the line and I think most all of the complaints have been about the 320RS. The best place to find out about issues with these units is to join the Columbus RV Group on Facebook. We have over 1000 members and they can answer any of your questions.
Thanks. Sent a join request over there.
I noticed ours was much heavier than others I looked at with a 12,222 dry weight on the sticker on camper. the few other 295s I looked at were in the 10k range so Im Wondering if maybe mine has some of the items you mentioned done already. Not sure.
