Old 07-10-2013, 02:24 PM   #11
Send a message via ICQ to ByronCR Send a message via AIM to ByronCR Send a message via MSN to ByronCR Send a message via Yahoo to ByronCR Send a message via Skype™ to ByronCR
I actually use the outside tank, and the single tanks before I use the 2nd inner tank. My main reason for that is that its much more difficult removing the 2nd tank on the slide than it is removing the single or the outter tank. Just how I am doing it, but I still use it as a "Backup"
Byron R
2013 Columbus 295RL
2006 F350 6.0L Crew Cab LB SRW
ByronCR is offline   Reply With Quote
Old 07-11-2013, 08:03 AM   #12
BigTJohn's Avatar
Yep, same way I mentioned. I do have all three on however. The auto switch will (hopefully) do its job and then I do as you wrote.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 07-11-2013, 09:19 AM   #13
My single tank doesn't start flowing until both the curb side tanks are empty. I think the regulator on the single tank is set at a slightly lower pressure so it won't flow into the line until the pressure drops as the double tanks empty. My plan is to plumb the two outer tanks together and replace them with 30 lb cylinders. Then the inner 20lb tank will serve as the reserve.
2013 Columbus 340RK
2006 2500HD 4WD 6.0l
Harneymaki is offline   Reply With Quote
