Old 09-13-2013, 06:34 PM   #1
cstover's Avatar
320RS and 365RL pin weight
Does anyone have real world numbers on pin weight and total weight for those 5ers. Thanks
cstover is offline   Reply With Quote
Old 09-14-2013, 06:40 PM   #2
Jimmerinwi's Avatar
I would think that would depend on how much weight YOU add, water, supplies, beer.
Some days I wake "Grumpy", Some days I just let her sleep......(Ray Scott)
Jimmerinwi is offline   Reply With Quote
Old 09-14-2013, 07:49 PM   #3
Weight
The best way I have found for accurate load/weight is through a truck scale at a truck stop. Take 3 readings
1 - all axles from truck and trailer on the scales
2 - rear axle of the truck and all axles of the trailer on the scales
3 - Trailer axles only on the scales
Addition and subtraction will give you steer axle load, hitch or 5th wheel load and trailer axle only load.
Price will vary but the peace of mind of knowing is worth it. Actually got a reading at a landfill scale once for free.
wheelmangg is offline   Reply With Quote
Old 09-14-2013, 11:26 PM   #4
cstover's Avatar
I have all the current weights for my trailer. We are shopping for the next one. Just wondering if anyone has weighed thier 320RS or 365RL
Old 09-15-2013, 09:46 AM   #5
Have a 2013 320RS. Had weight taken at each wheel on trailer and truck. Camper had about 1/4 of fresh water, all other tanks were empty. Loaded with normal camping gear for a two week trip. Weights as follows: LF=2675 RF=2625 Total front axle=5300 (700 under max). LR=2875 RR=2600 Total rear axle=5475 (525 under max). Pin weight=3100 Total trailer weight= 13,875. Only 140 lbs under max.
skydriver is offline   Reply With Quote
