Old 03-12-2013, 08:36 AM   #11
Herk7769's Avatar
Sidney- to be honest, I didn't base any of my math off of dry weights or option weights or anything but the trailer's gross weight (GVWR). All of the other things are variable but the gross weight is a static that should never been exceeded. If you're safe for it, you'll always be safe no matter what the dry weight is (imaginary or real) or what options you pick or how many s'mores supplies you take.
This is the recommended practice. If your truck can not tow the camper at its maximum weight, either the camper you selected is too big or the truck you are planning to pull it with is too small.
Also remember for 5th wheels, 15-25% of the camper's total weight must ride IN the pickup's bed for stability. Make sure the truck has the avialable payload (after family, hitch, and truck gear) to carry that weight without exceeding ITS GVWR.
HAM CALLSIGN - KC3FFW
Old 03-12-2013, 09:52 AM   #12
I totally agree... I should be using the trailers GVWR to match a 5th wheel to our truck.
But... you know how it is... you start looking at coaches and the ones you like weigh more than you expected.
I am using 1000 lbs as a cargo capacity to add to the actual dry weight and trying to stay under our trucks tow capacity of 12500.
2011 Ram 2500HD, CC, SB, AT, HO 6.7 CTD, 3.73 axle
It's difficult to choose the right rig when every dealer we meet tells us we have plenty of truck to tow these heavier trailers... and when I see so many similar trucks towing much larger trailers on the road.
I called my truck dealer about buying a new truck and even he said our truck is fine... we don't need new truck.
sidney is offline   Reply With Quote
Old 03-12-2013, 10:19 AM   #13
Fulltime family RVer
sidney - I feel ya. I'm having that *exact* discussion with my father-in-law!
Here's our saga - Backing into Towing Capacity
Old 03-12-2013, 10:40 AM   #14
Herk7769's Avatar
There is a scene in "Planes, Trains, and Automobiles" where people in a car on the other side of the highway were yelling, "You are going the wrong way!" John Candy says, "They're Drunk! How the heck do they know where we are going?"
Your so called "dealer" has no idea what your remaining payload will be after your family, hitch, and gear are loaded into the truck. He is looking at a manual showing the towing capacity with the truck EMPTY and a 150 pound driver.
My GMC 2500HD with Duramax Diesel and Allison Transmission has a tow rating of 15,500 pounds (5th Wheel) and a max GVWR of 9300 pounds. My pin PAYLOAD is maxed out at 1500 pounds due to my family and what I carry in the truck. (10,000 pound 5th wheel max camper weight @ 15% pin load).
Name:	Camper photos 004.jpg
ID:	25506   Click image for larger version
Name:	Camper photos 005.jpg
Old 03-13-2013, 01:02 AM   #15
herk7769
Respectfully... Regarding my dealer, you are making your own assumptions without knowing what I have discussed with my "so called dealer". He is a friend and a man I trust.
All the best,
Sid
Old 03-13-2013, 06:05 AM   #16
Grape Escape
I would be more worried about your payload capacity. One of the reasons I shyed away from the Dodge 3/4 ton.
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline   Reply With Quote
Old 03-13-2013, 06:38 AM   #17
Trailer Towing Guides | Trailer Life Magazine
grayfox is offline   Reply With Quote
Old 03-13-2013, 09:04 AM   #18
Sidney -
I know you already have the truck and have been told multiple times that it'll be ok. What I think it comes down to - you have the tools to make an educated decision. You can choose to stay fully within your limits or you can choose if you're going to exceed some or all of them. Many make choices that they're only going to adhere to specific weight limits (keeping within rear GAWR but exceeding GVWR or GCWR).
Best wishes.
Old 03-13-2013, 09:19 AM   #19
Here's another tool. hope it's helpful
http://changingears.com/rv-sec-tow-vehicle-sizing.shtml
Old 03-13-2013, 09:42 AM   #20
Herk7769's Avatar
herk7769
All the best,
Sid
Sid,
No foul intended.
Just that without actually weighing your truck "ready for camping with family on board" and determining your actual remaining payload, your good and trusted friend has no idea how much camper you can safely tow.
Herk
