Old 04-01-2014, 08:23 PM   #1
340RK Axle
We have a Columbus 340RK that is only about six months old so the warranty still applies. I noticed that the door side, front tire is wearing on the outside edge. The other tires are just fine. The service department where I had it in for some repairs said that leaving the fresh water tank full when towing would cause that. Just doesn't sound right to me. They are going to check with the factory to see what they say. Has anyone else heard this before? Thanks for any input.
Jim & Linda
2012 Dodge 2500, Diesel (of course)
2014 Columbus 340RK
jeb182 is offline   Reply With Quote
Old 04-02-2014, 05:39 PM   #2
BS in my opinon. If you can't haul fresh water without damaging something then the build quality is sub par. Sounds like a bent axle to me.
Why would they put the weight of a full fresh water tank on the cargo sticker if it wasn't advised to haul it?
goduc is offline   Reply With Quote
Old 04-02-2014, 05:54 PM   #3
Suspect the axle is either bent or mis-aligned. Measure between the tires or better yet, between the spindles on both sides to get some idea.
Old 04-02-2014, 06:49 PM   #4
DDC
DDC's Avatar
Wow never heard that before ask for it in writing:rollback: There is a problem with the axle (bent?)
It's hard to believe that they would expect people to trust them.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 04-04-2014, 11:58 PM   #5
Axle
Sounds fishy to me. I have had axle and slide issues with my 340RK. Go directly to Columbus warranty department or even Lippert. If dealer is hasing you. I have had to do this yo get anything done.
Good luck
Jczreed is offline   Reply With Quote
Old 04-05-2014, 12:15 AM   #6
SYE
SYE's Avatar
Found this on the Columbus RV Group FB page today. Seems the NHTSA has given Lippert and FR until May 9th to provide ALL the documentation regarding this VERY SERIOUS ISSUE! More to follow as it becomes available!
http://www-odi.nhtsa.dot.gov/acms/cs...4008-59099.pdf
http://www-odi.nhtsa.dot.gov/acms/cs...4008-59098.pdf
http://www-odi.nhtsa.dot.gov/acms/cs...14008-6919.PDF
If you haven't filed a compliant with the NHTSA, it's not too late! Please go to their website and file, even if you have had the repairs done, it is imperative that we get ALL the information out there to hopefully force a recall and prevent someone from getting seriously injured and/or worse, killed. THANKS!
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 47 reserved
SYE is offline   Reply With Quote
Old 04-05-2014, 04:34 AM   #7
Witch Doctor's Avatar
Sye wouldn't that apply to all axles no matter if it's a Columbus or not. I don't know don't they use the same axle on other models to, or is it a special axle for Columbus only?
Coachmen M/H
Concord
2018 / 300 DSC
Old 04-05-2014, 10:43 AM   #8
SYE
SYE's Avatar
As far as I know, yes it would. They make axles for all of the campers, Columbus is the ones that the original complaint was logged against. So now it is an issue with all of the FR products that use Lippert Axles. The investigation begins.
Scott & Vicki
Old 04-05-2014, 12:02 PM   #9
DDC
DDC's Avatar
Highlights the importance of reporting safety related issues to the proper authorities.
Old 04-05-2014, 05:17 PM   #10
Thanks for all of the input. It is treaty appreciated. When the service department started with their lame explanation I was immediately suspicious, but I wanted to see if anyone had heard of problems when carrying a full fresh water tank. I will call Columbus if I can find a number. Does anyone happen to have a good number for warranty issues?
Jim & Linda
2014 Columbus 340RK
Old 04-05-2014, 05:35 PM   #11
SYE
SYE's Avatar
Columbus by Palomino
105 14th Ave.
Middlebury, IN 46540
Sales: 574-821-1505
Service: 574-821-1487 (Cel Lopez) (Warranty Manager)
Parts: 574-821-1540 (Kaylan Stake)
Parts Fax 574-821-1513
Jack Plummer (574) 201-4810
Scott & Vicki
Old 04-05-2014, 06:41 PM   #12
Axles
Go to the Pamamino website. Under columbus there is a contact section. The numbers are there to call, or you can send them an e-mail.
They are usually fairly quick to reply.
Good luck
axle
