Old 03-28-2012, 08:30 AM   #1
westyguy's Avatar
34REQS-6 with X-Chocks
The tires are so close together on our 2012 34REQS-6 that my X-Chocks will not slip in between. Does anyone know of another chocking system that adds stabilization and will work with our camper.
Harland & Nita from Texas
Rusty & Coffee - Guard Dachshunds
2012 Sabre 34REQS-6
2011 F-250 CC/SB/6.2L Gas/2X
Nights Camped 2012 = 14
westyguy is offline   Reply With Quote
Old 03-28-2012, 09:12 AM   #2
You could make your own but you will have to adapt the angle for your tires. Links:
Homemade Wheel Chocks
Wheel Chocks
I made a set for our 2nd camper and they worked very well. When we bought our 3rd camper I had to cut the blocks at a different angle because of the spacing of the tires. Looks like I'll probably have to redo again when our Sabre comes in.
Old 03-28-2012, 09:20 AM   #3
I thought I had the same issue when I got our new TT. My old TT axles were farther apart then the new one. When I went to put them in I thought they were at their thinnest setting, I even tried to make them maller by turning the adjustment screw. Only after looking closely, and feeling like an idiot, did I notice that there was plenty of adjustment left to make them smaller. It just took more muscle to turn the adjustment then I was expecting. Not saying that's your issue, but your axles must be really close if they don't fit. How far apart are the tires?
Len & Cheri is offline   Reply With Quote
Old 03-28-2012, 12:48 PM   #4
ret2006's Avatar
I have X-Chocks for my 2012 31 RETS-6. They are very tight but you can use the wrench to close them all the way. They should go in. Good part is you don't have to tighten them much. Quick install.
2014 Cedar Creek 34 RLSA-7
2015 Chevy Silverado 3500HD LTZ SRW
ret2006 is offline   Reply With Quote
Old 03-28-2012, 05:20 PM   #5
H2oski
X2 with ret2006
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
h20ski is offline   Reply With Quote
Old 03-28-2012, 06:47 PM   #6
westyguy's Avatar
Thanks to all for your replies. I have them cranked down so tight I just about need a cheater bar to get them operate. I haven't actually measured the gap between the tires but it is tiny.
Thanks again
2012 Sabre 34REQS-6
Old 03-30-2012, 01:04 PM   #7
jsk
If you find some chocks that fit the 34-reqs please post. There is very little gap between the tires. We have not used the tire chocks because our previous 5er had the JT stabilizer bars which worked very well. We will be looking for tire chocks and hope they hold as well as what we read they do.
jsk is offline   Reply With Quote
Old 03-30-2012, 01:44 PM   #8
westyguy's Avatar
Will do. If, by chance, you end up putting a stabilizer system on your's, I would really appreciate knowing how that works. I can tell you that I used the X-Chocks on my TT and really couldn't tell much difference with them installed. I read a lot of positive comments about them, but that wasn't the case with my TT.
2012 Sabre 34REQS-6
Old 04-02-2012, 03:08 PM   #9
We're using the X-chocks on our new 32 RCTS. It is a very tight fit but, I've found by bending the "shoes" just right to follow the circumfrence of the tires, they can be wiggled on.
I don't know why the axles are so close.
Cathy & Jeff
Midland, Michigan
2013 Sabre 32RCTS / 2012 Ram2500 Hemi
SimchaSabre is offline   Reply With Quote
Old 04-02-2012, 09:13 PM   #10
westyguy's Avatar
Appreciate that Simcha. I've tried adjustingnthem so they line up just right and still no luck.
2012 Sabre 34REQS-6
