Old 04-24-2013, 10:04 PM   #31
Just looking at the advertised pin weights for all the sabre 5ers they are all about 1800 -2000 lbs. what is the average available payload of a 2/4 ton truck.
Brandon327 is offline   Reply With Quote
Old 04-24-2013, 10:07 PM   #32
QCCowboy's Avatar
LOL....you thinking about seeing if a 150/1500 will work???? Lets not go there...
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
QCCowboy is offline   Reply With Quote
Old 04-24-2013, 10:31 PM   #33
Fulltime family RVer
Just remember, the advertised pin weight is artificially and unrealistically low.
ependydad is online now   Reply With Quote
Old 04-24-2013, 10:33 PM   #34
To answer the second part of your question- I don't know what 3/4-ton trucks payloads typically run.
As well, I think I mentioned before- I was surprised how much payload my add-one and family ate up per my scale receipts.
Old 04-24-2013, 10:35 PM   #35
I know they are low. If you use real world pin weights then a 3/4 on truck is not capable of pulling anything more than an atv trailer by the time you add people and a hitch . A regular gooseneck trailer unloaded probally exceeds the the payload of most. 3/4 ton trucks.
Old 04-24-2013, 10:40 PM   #36
You're probably very right. I've read here that most people with 3/4 ton trucks exceed GVWR but are comfortable as long as they're under the rear axle and tire weight ratings.
Old 04-24-2013, 10:48 PM   #37
QCCowboy's Avatar
Wish I would have taken a picture of my '10 F250 sticker, but I want to say available was somewhere in the 2300 lb. range. I could be way off base here though.
2014 Sabre 36QBOK
Old 04-24-2013, 11:57 PM   #38
... but are comfortable as long as they're under the rear axle and tire weight ratings.
Is that not what is the limiting factor? If the trailer is level and the truck is level and the tire/axle limits are not exceeded what is the problem if the eng will pull it?
Old 04-25-2013, 09:08 AM   #39
There's already a thread on exceeding ratings or not. Let's keep that discussion there.
Thanks.
Old 04-25-2013, 09:33 AM   #40
Originally Posted by f1100turbo View Post
Not enough truck.
1 ton dually my friend.
Turbs
Please don't just conclude that if you need a 1-ton that it needs to be a dually. Going to a 1-ton adds about 1000# of payload, and going DRW adds another 1000#. If you need 1000 more, but not 2000 more, then you don't have to go dually!
