Old 04-23-2013, 11:09 PM   #1
36qbok and a 3/4 ton truck
Who is a pulling a 36qbok with a3/4 ton truck? i currently have a 09 gmc 2500 hd cc short bed 4x4 with duramax Allison combo. I want to gets a new 36qbok but I am thinking my truck will be maxed out on payload. I don't want to get a new truck because the one I have is almost paid for and only 40k miles on it.
Brandon327 is offline   Reply With Quote
Old 04-24-2013, 05:15 AM   #2
from what I see with a hitch weight of 1825 plus the hitch you are not going to be happy. I am sure you can pull it but I do not think you have enough truck.
bob34787 is offline   Reply With Quote
Old 04-24-2013, 06:23 AM   #3
TURBS's Avatar
Not enough truck.
1 ton dually my friend.
Turbs
Old 04-24-2013, 06:50 AM   #4
Camper Less Camping
Cajun Po-Boy's Avatar
Engine & Tranny are capable, unfortunately the truck's weight limitations are not enough for that camper.
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 04-24-2013, 06:50 AM   #5
Lynkage's Avatar
The 36QBOK is basically the same trailer as my 355BHQ. It was too much for my 1 ton SRW. My payload was gone before I even put my family in the truck.
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
Lynkage is offline   Reply With Quote
Old 04-24-2013, 07:17 AM   #6
Always Learning
The hitch weight on mine weighed in at 2,300 pounds wet and that was *without* any propane (sigh- apparently (sheepish grin)) and that was the first trip of this season before we were able to accumulate crap as the year goes on. It was with minimal water in the gray and black tanks since I was winterized (I don't always dump between trips if I'm going again soon). And, my air compressor wasn't in the basement storage like it usually is (it was further back in the doorway). No firewood or anything.
All told- I surely believe that my pin weight number is going to so nothing but go up.
Brandon- take your family, some stuff representative of your traveling goodies, hitch and go get your truck weighed. It'll tell you what your actual payload is. As you probably read in my weighing thread, my advertised vs. actual payload was a good 1,200 pound difference when we were ready to go.
Also, look for member bjlowe, he's pulling a 36qbok with less truck than I have (man- that sounds insulting but surely isn't meant to). I just don't know if it's a 3/4-ton truck or 1-ton Megacab.
Old 04-24-2013, 07:32 AM   #7
QCCowboy's Avatar
Wouldn't risk it with anything less than a 350/3500 series truck. You would most likely run out of payload before putting any passengers or gear in.
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
QCCowboy is offline   Reply With Quote
Old 04-24-2013, 08:51 AM   #8
amxpress's Avatar
Before all this debate continues what are the towing specs of your Chevy? Payload? Towing capacity? GVWR? Etc.
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline   Reply With Quote
Old 04-24-2013, 09:03 AM   #9
TURBS's Avatar
Payload on that truck should be about 2450 lbs .
The math is uber simple here.
2450- 1850 = 600lbs left
1 ton dually period
Old 04-24-2013, 09:30 AM   #10
TTNewbees's Avatar
1 ton dually period
Guys, I am still confused by all this payload stuff, as I have been contemplating what 5er I can safely tow. I have an f250 diesel and I am thinking based on reading here that regarding the pin weight I will need to be below 2k. Back to posted topic.
Then I am reading this....
It's mentioned he needs a 1 ton dually? See picture below from Palomino website.
Turbo, don't you have a 3/4 ton? According to this your hitch weight is 1872lbs.
I am by no means trying to point anyone or anything out, just trying to decipher through these posts to make smart decision for myself in the future and from all I have read I won't be capable of towing a 12k trailer with 2k pin weight. But it seems everyone is doing it looking at people's profile and tv's.
Just sayin, pass the corn and 3d goggles...
Mike
2012 Lacrosse 303RK
2012 F250 6.7 diesel
TTNewbees is offline   Reply With Quote
Old 04-24-2013, 09:41 AM   #11
TURBS's Avatar
Yes I do but look at all the weights and lengths.
That pin weight listed is for a 2013/14 32bhok
I have a 2011 and its less.
36qb is 4 ' longer than a 32bh
Not apples to apples my friend.
Now look at uvw 36qb is 11, 840 lbs
32 bh is 2, 300 lbs less
Old 04-24-2013, 09:52 AM   #12
TTNewbees's Avatar
Sounds good, that answers my questions. No problems being over payload capacity, keep length and total weight in check, thanks!
Mike
2012 Lacrosse 303RK
Old 04-24-2013, 09:55 AM   #13
Always Learning
1 ton dually period
It's worse. My actual wet pin weight was 2,300 pounds:
2,450 - 2,300 = 150 pounds.
Now, think about the goodies that we add onto the truck after it leaves the dealer's lot - truck bed cover, 5th wheel hitch, fancy lock thingamajig for the tailgate, etc.
If you're going to stick to the ratings, the truck with a 36QBOK is going to be over before you load up the family.
Old 04-24-2013, 09:56 AM   #14
Always Learning
That's one opinion.
The other opinion is that all of the ratings matter and you shouldn't exceed any of them.
Old 04-24-2013, 11:15 AM   #15
Scratch's Avatar
Been there & done that, unfortunately... Cost us some bucks deciding to upgrade to an F350/3500 or go with a lighter 5er.
It was a tough decision as the 36' Cougar had the exact floor plan we wanted. With a new truck bed cover, bed liner, 5er hitch, DW, big puppy, airbags, firewood and camping gear, however; we were already near payload, and the loaded trailer's hitch weight put us well over all specs. Took a quick trip to the Texas coast and I knew that although I had plenty of hp and torque, that big rig was obviously made for a one-ton truck.
When we returned home, I gave serious thought to proceeding with what we had because even though the towing comfort wasn't what I wanted, I noticed on several forums that lots of folks tow over their TV's manufacturer's ratings and read the reasons why they do so.
DW then planned a trip with our two young granddaughters and my decision was much clearer and easier... We sucked it up and traded a nearly-new Cougar for the PT Crusader and gave up 5' of length and 2,000 lbs. in the process. There was a moderate, but reasonable increase in price, but the Crusader is the perfect match for my TV. We can all pile in, it drives great, and I sleep well at night. We learned the hard way, but benefitted in that we are happy to be back in the Forest River family, the Crusader is better constructed, and Prime Time has incredible customer service.
Next unit, easily five years out following this experience, will be a larger Prime Time 5er, then an F350 or F450 to match the towing requirements per manufacturer specs...
Scratch sends...
'12 nights camped: 12
'13 nights camped: 24
'14 nights camped:
Scratch is offline   Reply With Quote
Old 04-24-2013, 11:59 AM   #16
The way I have it figured a average 3/4 ton truck only has about 1000 lbs of available payload for pin weight or tongue weight on a trailer. So there fore you would never be able to pull much of anything. Gcwr of a truck is much less than the gawr. Where do they get payload figures from? The way I see it a as a farmer we are always overloaded just with a empty gooseneck trailer.
Old 04-24-2013, 12:22 PM   #17
mhuffs9017's Avatar
Just came from a 3/4 to a 1 ton dually just prior to picking up our 36qbok. I'm glad I made the move because this thing is HEAVY and LONG. Our initial drive had us in 30-40mph crosswinds and I didn't even grip the steering wheel while cruising @ 65mph. I would go with the larger tow vehicle, for your sake, and the sake of others on the road. While these limit postings on the truck are more to cover the manufacturer it makes more sense to follow them in cases where liability could be claimed if an accident were to occur.
Stay safe and have fun. Life doesn't always have to be about pushing the limits.
2013 F350 DRW 6.7 3.73 - Lariat Ultimate FX4 - Tuxedo Black - 14K GVWR
2013 Sabre 36QBOK
2012 Rinker 246BR - "Off The Grid"
Nights Camped 2013 - Not enough!
mhuffs9017 is offline   Reply With Quote
Old 04-24-2013, 05:38 PM   #18
QCCowboy's Avatar
Did you get your question answered OP (Brandon327)? Does anyone remember what that question was?
2014 Sabre 36QBOK
Old 04-24-2013, 05:40 PM   #19
TURBS's Avatar
I do .
Should you pull a 36qbok with a 3/4 ton duramax.
Answer is NO .
Old 04-24-2013, 05:48 PM   #20
AquaMan's Avatar
Should you, probably no. Can you, definitely yes. I love kettle corn! Pass it down, please.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
