Old 06-19-2017, 08:52 AM   #1
383FB black tank flush on panel no hose is connected?
There in no hose connected to the black tank flush connection on the panel? when I tried to flush the tank with the black inlet connection it just flooded the the rv's basement
This unit has a half bath and has 2 black tanks, and there is a second "blank tank flush" to the right of the panel. this one works.
jmaffucci is offline   Reply With Quote
Old 06-19-2017, 08:56 AM   #2
AquaMan's Avatar
Check behind the panel. The hose may have just come off.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 06-19-2017, 10:43 AM   #3
383fb
I did it aint there no hose???
Old 06-19-2017, 10:50 AM   #4
AquaMan's Avatar
So there is a connection, but no hose? Check inside your bathroom cabinets and see how many vacuum breakers there are. If there are 2, the line is probably in there somewhere, but not pulled all the way through into the panel area.
Old 06-19-2017, 10:55 AM   #5
AquaMan's Avatar
You're looking for something like this.
Old 06-19-2017, 01:10 PM   #6
383fb
This is what I have.
Old 06-19-2017, 08:56 PM   #7
AquaMan's Avatar
Just one or are there two? Check both baths. Mine were both in one bath, but I've seen them in both.
Old 06-20-2017, 06:10 AM   #8
yea, I tried to flush both tanks with the connection to the right of the panel but it only flushed the front black tank. I will try again this am. thanks so much for your help
John
404 580-7714
Old 09-15-2017, 11:38 AM   #9
Sounds like they forgot to connect the hose in back of the hose connection in the water closet. Factory goof up.
In our 2017 383FB I find it odd that the right black flush connection flushes the front bath black tank and the connection on the back panel flushes the rear 1/2 bath black tank. The Front black handle dumps the rear 1/2 bath black and the rear black handle dumps the front bath black. Counter intuitive in my opinion. And why have two dump connections?? Route it all into one like most trailers. Odd design!!
condojj48 is offline   Reply With Quote
Old 09-17-2017, 05:21 PM   #10
I also have a 383FB 2017 Had to label all connections and valves. No rhyme or reason. The lables on the side of the rig re just as bad.
John & Carol
2017 Columbus 383FB
1999 F550 7.3
Livingston, Texas
Cane Raiser is offline   Reply With Quote
black, black tank, black tank flush, flush, tank
