05-30-2013, 09:52 AM
#21
Always Learning
Originally Posted by youroo
I do not want to get into your financial situation,but after spending (300$ x 2),for Steps (5$ x 2) for jacks seems small$. Youroo!!
Ha. I see how you arrived at that conclusion - I just meant the whole project was pretty spendy (steps AND the jacks for it). I wouldn't do one without the other.
05-31-2013, 03:12 PM
#23
Any suggestions on where to buy a four step to fit the Columbus 320RS?
06-09-2013, 10:14 PM
#25
Unfortunately, the quadra steps aren't working out so well. I tried installing a set on the half bath door on Friday. They bolt up fine, but the way they're built/operate doesn't work with the factory brackets, unless I cut some of the bracket out. They also don't work with the tan trim that goes around the OE steps. It could be worked out, but I'm not sure I want to go through the process. Now I'm debating on sending them back and taking the hit, modding them to make them work, or trying to sell them. If anyone is interested, PM me and I can better explain via phone.
LINK TO MY MODS
2012 F350 King Ranch DRW 6.7L
2013 Sabre 36QBOK-7 Platinum Package
06-09-2013, 10:41 PM
#26
Originally Posted by ependydad
I see you need (8-1/2)in.to deploy these supports.So they are unusable most of the time? Especially if used with quad steps! Youroo!!
06-10-2013, 10:37 AM
#27
Always Learning
Interesting. I didn't even think about that - you're right, with the quad-steps, it's likely to be less than 8 1/2" from the bottom step to the ground.
06-10-2013, 11:03 AM
#28
Also, with the added distance away from the camper, it is going to put a tremendous load on the hanger bolts and the framework in the bottom of the door frame. I doubt they would not damage the door frame without the additional support. The 3 step ones stick out 24", so a 200# person standing on the bottom step exerts 400 lb/ft of torque on the framework and the 4 step would load it to approx. 533#+.
