Closed Thread
Old 01-18-2013, 09:11 PM   #21
I guess my question would be about wheels while hooking up. Should they be chocked or should I leave x clocks in place during hookup and pull test or not? JT
Jtant is offline
Old 01-18-2013, 09:15 PM   #22
asquared's Avatar
One trick I have seen is to paint the jaws of the hitch a bright color or white so you can visually see it is closed easier.
asquared is offline
Old 01-18-2013, 09:25 PM   #23
JDWeir's Avatar
In my opinion, I would take the x chocks out and use regular wheel chocks. The wheels should be able to move slightly in relation to each other when raising or lowering the coach with the landing gear. It may work to leave them in, but I think I would take them out.
TV, 2000 Dodge RAM 2500 Quad cab short bed, Cummins 5.9, Edge Comp, Gauges.
5ver, 2011 Palamino Sabre 31 RETS.
JDWeir is offline
Old 01-18-2013, 09:29 PM   #24
phat phrog stunt crew
thanks jd for taking the time to type out diections for those that dont know or are worried about the first time hooking up fifth wheel. you can save yourself an additional walk around inspection of the lights by turning on either headlights or parking lights along with 4 ways.
dwaynerz is offline
Old 01-18-2013, 09:34 PM   #25
Fulltime family RVer
Wheels chocked and I actually leave the landing gear entirely down. I follow the instructions that B&W provides:
http://www.turnoverball.com/sites/de...07_12_2012.pdf
(Steps 5 & 6)
I leave whatever wheel chocks in that I have in- be it between the wheel chocks or the behind the wheel chocks.
ependydad is offline
Old 01-18-2013, 09:39 PM   #26
JDWeir's Avatar
You can certainly do this, I have just found that in brighter daylight, it seems easier for me to check one element at a time. I also like the extra walk around, I am kind of a "belt and suspender" kind of guy....
Of course the extra exercise helps too...
JDWeir is offline
Old 01-18-2013, 09:45 PM   #27
JDWeir's Avatar
(Steps 5 & 6)
Good point ependydad.
I guess my thinking is that if the coach moves any with the landing gear down, it could mess up the landing gear. But if you are chocked good, the coach should not move, thus no worries about the landing gear.
JDWeir is offline
Old 01-18-2013, 10:24 PM   #28
That's the idea for me- between the wheel chocks and I ALSO hold the trailer brake so the trailer shouldn't move. I've also been getting a little more aggressive when trying to pull away from the camper from reading the "dropped my fiver" threads.
I think that as long as you're doing *A* pull-test, you're good.
Old 02-11-2013, 06:27 AM   #29
BigTJohn's Avatar
Do not leave the X-Chocks installed. They are not designed to withstand that much twisting and rotational/counter rotational force. Use "standard" wheel blocks/chocks.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline
Old 02-11-2013, 07:23 AM   #30
Herk7769's Avatar
If you are worried about "dropping the fiver" check out:
Butch's 5th Wheel Latch Kit
Also MAKE SURE you have your X-Chock removed before you move your camper. If you drive off with an X-Cock in the edges of the chock (as it rotates) WILL break your steel belts. The tire(s) may not blow immediately. It may take many miles for that broken wire to make its way to the surface and cause a blow out.
HAM CALLSIGN - KC3FFW
Herk7769 is online now
Closed Thread
5er
