Originally Posted by sanmarco
Hi, Having quite a bit of experience in heavy vehicle transport engineering, it appears that this is a characteristic common to short wheel bases. The position of the turntable may allow the weight to throw forward when going over a bump which would allow the rear axle to kick.It would be interesting to know your truck front and rear axle unladen weights compared to the same axle weights with the trailer hitched. The measurement of the king pin position forward of the rea axle would also be required.
Last year's numbers on a CAT scale (Certified Automated Truck) with front truck wheels same location each time.
Steering ax 4360 4460
Drive Ax 3280 5420
Trailer Ax 0 9640
Gross lbs 7640 19520
Pin/hitch plate installed according to instructions and appears over the axle or slight forward 1 or 2 "
I believe all within vehicle specifications.
What affect does this have? Any published info that a nonexpert could understand?
What about the pin and hitch movement?
