Old 12-28-2013, 07:12 AM   #21
I have the 6 point electric leveling system. The only problem I have ever had was self inflicted. I didn't push the pin all the way through when dropping the leg on the back. Camped fine, when I rigged down it snapped the pin. I double check and carry spare pins as well now
rmason8092 is offline   Reply With Quote
Old 01-01-2014, 09:39 PM   #22
This Lipper Ground Control 6 Point system makes leveling enjoyable for new campers like us. Press "AUTO LEVEL" When auto level is complete, LCD indicates LEVEL SUCCESSFUL.
Has anyone tried to swap one rear jack plug with the opposite side's center jack plug (at the control where all 6 plugs attach). Place the control in manual mode and press "REAR" to extend one middle and one rear jack on the same side simultaneously to change a tire.
AnchorsAweigh is offline   Reply With Quote
Old 01-01-2014, 09:51 PM   #23
rracer5's Avatar
6 point on our Sanibel. Electric motor turns a hydraulic pump sooooooo.......it's both?
2014 Prime Time Sanibel 3250
rracer5 is offline   Reply With Quote
Old 01-01-2014, 09:58 PM   #24
iceblaze580's Avatar
I would think that if it's an electric motor running a hydraulic pump it's a hydraulic system lippert makes the 6 point leveling system in both electric and hydraulic
iceblaze580 is offline   Reply With Quote
Old 01-19-2014, 04:09 PM   #25
hihocarp's Avatar
That's what I thought they were, electric over hydraulic.
hihocarp is offline   Reply With Quote
Old 02-02-2014, 02:57 PM   #26
Just to let you all know.I went out to the RV yesterday and the 6 point auto level system worked perfectly. Could of been operfator error!!!!
Cajun Happy
2014 Columbus 365RL
2018 Silverado 2500 High Country
Cajun Happy is offline   Reply With Quote
Old 02-02-2014, 07:15 PM   #27
rracer5's Avatar
Operfator error!!! May a few too many last time trying to level it??
Just kidding.
Old 02-03-2014, 01:33 PM   #28
I have the 6 point on my 320RS. Its electric and works great. We have used it on 15 or 16 trips without an issue.
ee2810 is offline   Reply With Quote
Old 02-12-2014, 09:17 AM   #29
RECAT
REBCAT's Avatar
2014 Columbus 320RS with 6 point leveling system - its electric - slower than hydralic but easier to install and much easier to maintain. Works well.
As far as 6 versus 4 - the 4 outer jacks level the camper on both systems, the last to are stabilzers, and I believe are worth the price difference. As far as lifting the whole unit, I do not know if its recommended (I doubt it) but in my learning process it was done.
2013 GMC SIERRA SLT 3500 HD CC Z71 4X4
HENSLEY BDR3 TRAILER SAVER AIR RIDE HITCH
BLUE OX BED SAVER
2014 COLUMBUS 320RS
WAR EAGLE !!
REBCAT is offline   Reply With Quote
Old 02-26-2014, 10:43 PM   #30
I've got the 6 point leveling that is electric
What kind if any, jack pads do you use in front of and behind the axles where the levels come down?
Thanks!
fivermann is offline   Reply With Quote
Old 02-26-2014, 10:58 PM   #31
I use the yellow Lego blocks
Old 12-30-2014, 05:16 PM   #32
Electric and works very well.
seahawk986 is offline   Reply With Quote
Old 01-01-2015, 10:34 PM   #33
Swift2
Swift 2's Avatar
We are also electric Andre like it so far. The rig is really solid.
Swift 2 is offline   Reply With Quote
columbus, leveling
