Old 06-18-2016, 09:41 AM   #1
A/C cooling issue
So I just purchased a Columbus 377RLMB. I have two A/C units, the rear which is a 15000 btu and the front a 13500 btu. My problem was that I was unable to cool the unit down. I was just running the rear unit. When I bought the RV I was lead to believe that the rear unit was for the living area and the front unit was for the bedroom area. After discussing my issue with the service department that is not entirely accurate. The system is designed with both units to work together. However, this also requires 50 amp service. I have been trying to cool the unit on 30 amp service and just the rear unit. The service dept. tells me that I can not run both units on the 30 amp service, Had I been told this when I purchased the RV I would not have bought it. Both units are tied together in the same duct system so there is no way to shut the front off from the rear. I mainly camp at state parks which only supply 30 amp service. So, my question is has anyone had the same issue, and secondly, is there a fix for it.
jamo955 is offline   Reply With Quote
Old 06-20-2016, 10:46 AM   #2
Yes, you cannot work both units on 30 amp but this applies not only to Columbus but any FW with two unit. What I don't understand is why you cannot work one independently from the other. I have a 30 RKT an you can do it if you play with the thermostat. Yes, there are days we need both units to cool it down, this is our experience.
2017 Leprechaun 311 FS
Jeep Patriot and Cherokee as toad.
Enjoying retirement.
jonwisconsin is online now   Reply With Quote
Old 06-20-2016, 11:01 AM   #3
TURBS's Avatar
Any camper with two a/c units can only be run one at a time on 30 amp.
You can run one or the other independently.
You can make the bedroom a/c non ducted.
Also pull the filter on the 15k and check to see if the divider between the intake and exhaust has came loose and mixing return air with the exhaust air.
Mine had came loose.
Also with a digital thermometer make sure your exhuast air is 20 DEGREES cooler then intake air.
Sent from my SCH-R530U using Tapatalk
Old 06-20-2016, 06:47 PM   #4
TURBS's Avatar
Ok doing some testing tonight as im also on 30 amp.
Over the weekend it felt like our 15k wasnt up to the task, however so far on paper its fine!
Either a blocked duct or poor insulation could be the culprit.
Camper is also in full sun.
Turned a/c on at 430
430
Ext temp 90
Int temp 103
Ret temp 97
Exh temp 73
530
Ext temp 87
Int temp 95
Ret temp 86
Exh temp 59
630
Ext temp 83
Int temp 89
Ret temp 81
Exh temp 55
Old 06-20-2016, 07:48 PM   #5
TURBS's Avatar
730
Ext temp 81
Int temp 82
Ret temp 73
Exh temp 49
Old 06-21-2016, 08:25 AM   #6
BuckeyeChuck's Avatar
Does the fan cycle on and off often while the compressor stays on?
2012 F250 Super Duty
2013 Sabre 33CKTS
BuckeyeChuck is offline   Reply With Quote
Old 06-21-2016, 08:47 AM   #7
TURBS's Avatar
No
Old 06-22-2016, 05:17 PM   #8
Rmk2001800's Avatar
A/C cooling issue
If you know an electrician or understand how they are wired, split the front air off onto its on circuit by place a 12-2 extension cord plug between the front air and the campers breaker box. Then when your at a 30 amp place unplug the connection and run a drop to the connection for the front air and plug into your 20amp in the box then run you regular 30 amp to service the everything else in the unit. I always camped at state parks but they shut ours down over the winter and installed 50amp.
Name:	ImageUploadedByForest River Forums1466633779.009955.jpg
ID:	111856   Click image for larger version
Name:	ImageUploadedByForest River Forums1466633792.016350.jpg
Rmk2001800 is offline   Reply With Quote
Old 06-22-2016, 05:18 PM   #9
Rmk2001800's Avatar
I included the photos I put in my camper to do this- each box will have a 30amp and 20 amp.
Old 06-22-2016, 06:19 PM   #10
Flybob's Avatar
This may not work in a full campground. Usually three of the 30A pedestals are connected together upstream to a 100A breaker. If all three sites on any one 100A breaker use over 30A from their pedestal, you will trip the 100A breaker. This usually means finding a ranger to reset the 100A breaker as they are usually in locked panels.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
cooling
