Old 07-22-2016, 01:24 PM   #11
May want to check if the ducts are sealed where they terminate in front cap or rear wall/ cap. I have a Columbus 381FL that ducts were not sealed and was losing air out the front cap. Once sealed made a lot of difference. In addition you may want to consider dual pane windows.
compuman is offline   Reply With Quote
Old 07-28-2016, 08:03 PM   #12
I have a 340 RK with two air conditioners and they do the job.
jonwisconsin is offline   Reply With Quote
Old 07-30-2016, 12:52 PM   #13
tugboat369's Avatar
Have a 320rs with 2 AC units and can hang meat in there.
Camping from 2008, Life member Good Sam / KOA / iRV2
2014 Columbus 320RS
2011 Ford, F250, 6.7D, SRW
tugboat369 is offline   Reply With Quote
Old 07-30-2016, 04:42 PM   #14
I have the exact same 2017 camper, just had mine at dealer for 2.5 weeks. I own air conditioning company and told them what was wrong, factory was no help finally have them two options. Unit is short on air flow, roof is to restrictive, they could either add a return directly under units with dump zone dampers for quick cooling or remove entire roof and rebuild. Factory never did get back to dealer but they put in returns and that done the trick. I will add pictures later for you.
2017 Columbus 377MB pulled by 2016 GMC Denali 3/4 ton
HVACMASTER is offline   Reply With Quote
Old 08-04-2016, 08:22 PM   #15
Limo tint
If you have the windows limo tinted, paint your front door window, put insulation and foil bubble wrap in your skylight, your unit will stay a lot cooler. Once we had over 100 degree heat and it was so hot, so we put a water hose on the roof and let it run to cool off the roof. This should help you be cooler.
Kstedman is offline   Reply With Quote
Old 08-10-2016, 08:48 PM   #16
I'm here in a campground in Elkhart. It was 90, but 74 inside my 340RK
cooling
