Old 03-11-2014, 09:58 AM   #21
I'd just take it to the dealer and have them checked. If not low on Freon, then they need to figure out if it's a return issue.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 03-11-2014, 10:01 AM   #22
It is going to the dealer regardless. I am just trying to stay cool while I am out I'm it this week.
Brandon327 is offline   Reply With Quote
Old 03-11-2014, 10:04 AM   #23
Always Learning
I know this isn't helpful, but I *wish* my problem was an inability to stay cool! We're celebrating 60-degrees these days.
Old 03-11-2014, 10:07 AM   #24
TURBS's Avatar
As weezer stated air flow is a BIG BIG issue.
The fans sometimes can push it away fast enough.
Op its funny how none of your vents are closeable.
Mine all open and shut as well as rotate.
But we never shut them so...... no need I guess.
TURBS
Sabre owners united!
Old 03-11-2014, 10:07 AM   #25
It is not unbearable here. It is only 70 but we have a 2 year old that needs a nap and it gets hot in the rv with it sitting in the sun.
Old 03-11-2014, 10:10 AM   #26
I wish I had the necessity to turn the AC on
Old 03-11-2014, 10:11 AM   #27
TURBS's Avatar
I wish I had the necessity to have mine out of the shed!
TURBS
Old 03-11-2014, 10:13 AM   #28
TURBS
Took the cover off this weekend Leaving for FL in 10 days and need to get everything taken care of before then.
Old 03-11-2014, 10:14 AM   #29
TURBS's Avatar
Do this for now.
Turn fan to "on" and "high"
Keep a/c adjusted to a temp so it will cycle more often.
Removing filters may also do the trick for now.
TURBS
Old 03-11-2014, 10:24 AM   #30
Always Learning
Same here- none of my A/C vents are about to be closed or rotated. Just plain white circles with slats in the ceiling. I wonder if that was a change to Sabres after yours was built.
Old 03-11-2014, 10:41 AM   #31
TURBS's Avatar
I wonder.
TURBS
Old 03-11-2014, 10:18 PM   #32
Mine rotate but don't close.
Old 03-11-2014, 10:32 PM   #33
Oklahoma Proud
MillerTime's Avatar
Thats the way our '13 Puma was also. I folded up paper towls and stuck into it to block the vent partially in the bathroom... you would freeze when you were getting in and out of the shower otherwise.
MillerTime- Future Sabre Handler!!
