Old 01-12-2013, 03:37 PM   #1
A question about storage
We keep ours at home. Have a gravel driveway. Right now I have a raised area for the tires that is constructed of patio bricks. Here's my question. I have two large heavy duty long mats that are designed to be in the bottom of a horse trailer to give horses good footing. Would it be better for the tires to sit on the concrete patio stones or on those mats? JT
Jtant is offline   Reply With Quote
Old 01-13-2013, 03:10 PM   #2
Home Storage
I store my V-Lite on high grassy spot in the yard for the winter months. I have it on 2x12x10 with Lynx Levelers under the tires. The 2x12x10 to spread weight and the levelers minmize tire contact to a solid surface. The levlers have little tire contact and let water drain from the tires with air movement under the tires. I used this method for 4 years with a pop-up and the tire stay in great condition. Hope this helps!
Old Goat is offline   Reply With Quote
Old 01-13-2013, 04:19 PM   #3
gbpacker's Avatar
The most important thing went storing a trailer, in-doors or out-doors, is to keep the tires dry;not under water. Also suggest that the tires be covered to limit exposure to UV
gbpacker is offline   Reply With Quote
Old 01-13-2013, 06:05 PM   #4
rowdydog77's Avatar
Agree with gbpacker....high, dry, and covered.
2002 GMC Sierra C2500 HD 6.6L Duramax Diesel
2013 Sabre Silhouette 291BHTS
Pat, Michele and 2 old dogs, Shug & Sissy
rowdydog77 is offline   Reply With Quote
Old 01-14-2013, 08:55 AM   #5
Camper Less Camping
Cajun Po-Boy's Avatar
X3
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 01-14-2013, 10:23 AM   #6
daydreaming about camping
jeeplj8's Avatar
I have read several posts from tire manufacturer that claim a radial tire, properly inflated and not over loaded, will not deform under these circumstances. What causes the tire to degrade is listed below, basically UV radiation and water. Freeze/that cycles also are hard on tires. Bottom line, no tire should be used more than 60 months after date of manufacturer due to the rubber compounds breaking down.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
