Old 08-13-2015, 05:20 AM   #1
AC doesn't shut off
Wondering if anyone knows something about this, but my 2013 Sabre TBOK AC unit will turn on and run fine, but it will not shut off. The past couple of nights I have run it my wife says it never shut off. I have had to get up to shut it down from the thermostat. I set it to 72 but it doesn't seem as cold either when it first runs. Any thoughts or suggestions appreciated.
Nastyfoot is offline   Reply With Quote
Old 08-13-2015, 05:34 AM   #2
davel1971's Avatar
depending on the type of unit and type of thermostat, this may be normal. If you have a digital wall thermostat, set the fan to "auto". If your controls on on the unit itself, the fan will run all the time.
David & Lynn
Old 08-13-2015, 06:36 AM   #3
TURBS's Avatar
X2
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "24 nights"
Old 08-13-2015, 07:17 AM   #4
jeff64's Avatar
I've noticed the 13.5K Btu runs a lot longer in this TT over the previous. More sq footage I guess. I don't believe the standard T-stat is super accurate. Have yet to mount just a inexpensive thermometer near the T-stat to check calibration and derive realistic set point for the T-stat. But, I can raise the T-stat setting above where it was and the AC will shut down. The auto setting on the fan is a valid point.
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 08-13-2015, 03:23 PM   #5
What is the outside temp? If it is too hot you never will get it down to 72.
VMI'62
Edmund is offline   Reply With Quote
Old 08-13-2015, 06:22 PM   #6
Does anyone know if there's a way to rewire the thermostat on the unit to have the fan turn off when the compressor shuts off? I know it's normal to have the fan running full time, but it's very distracting when the compressor is off. Our unit doesn't have a wall thermostat. Thanks
gfarmcafe is offline   Reply With Quote
Old 08-13-2015, 10:02 PM   #7
Bluepill's Avatar
It is easy to rewire any unit so that the fan and the compressor turn on and off together. The problem with this set-up is that the thermostat sensor element is designed to have airflow across it from a constatnt fan, and will not work as well with the fan off. You usually end up with temperature swings of 4 or 5 degrees.
2008 Itasca Meridian 37H
Old 08-13-2015, 10:08 PM   #8
mud yapster's Avatar
Mine doesn't turn off either but I have it set to 65 deg. and it's 100 here everyday. LOL
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 08-19-2015, 09:38 PM   #9
I'd put money down that you have your thermostat set to "low" or "high" instead of "auto." The auto setting will run the fan at the appropriate speed but shut it off when the desired temperature is reached. The other two settings leave the fan on continuously.
campingguy is offline   Reply With Quote
Old 08-19-2015, 10:05 PM   #10
Blackhat6mike's Avatar
X3 Found this out the hard way.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
