02-19-2017, 09:23 AM
AC / Furnace come on @ same time
2017 Solaire 267 BHSK - took it home from dealer and was trying out the heat. When furnace comes on the air conditioning unit blows at the same time. Digital thermostat. Is it possible to change this setting so only the furnace comes on without fresh outside air (I'm in a fairly cold climate)
02-19-2017, 09:30 AM
Go to Fan setting on Thermostat and change to Auto. In Hi and Lo speeds, it runs the AC fan to help circulate warm air near ceiling.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
02-19-2017, 09:31 AM
Set the fan speed to "AU".
2015 F-250 FX4
Make sure your fan setting is on auto.If you have it on anything else the fan runs all the time.
Looks like we all answered at the same time.
2011 Ram Mega Cab 3500 Larimie dually
2016 Chaparral 370FL
Thank you! I'll give it a try!
02-19-2017, 09:32 AM
Thank you!
02-19-2017, 09:38 AM
I have a soldier also. Make sure the fan setting on the thermostat is set to "auto" and this should fix your problem.
02-19-2017, 09:39 AM
Solaire not soldier... [emoji23]
02-19-2017, 09:42 AM
Thank you. Very helpful forum!
02-19-2017, 09:54 AM
Congrats on your new rig.
As many have said, setting the digital thermostat to AUTO will keep the A/C fan from running. It will run if the setting is on LO or HI
Unfortunately, your dealer failed to give you some very basic RV 101 advice about how some of the systems work. Also, many folks come here thinking this is a problem. (when the A/C runs with the furnace) It is not, it is an option. Shame on the dealer for not fulfilling his obligations.
Warm air rises so the manufacturer (Dometic) gives you the option of running the A/C fan to help distribute that warm air throughout the camper. This is something a competent RV dealer should know and explain to you during the customer orientation.
Also, your A/C unit isn't pulling in any 'fresh' outside air. The air in the camper is recirculated throughout. This applies to both the A/C and the furnace. They are closed systems to the outside. The furnace for the purpose of not depleting oxygen (for combustion) inside the camper and the A/C for the purpose of using already cooled air to help continue to cool.
That's why it is always a good idea to utilize any vent fans/windows to initially draw the heat out of your camper when first firing up the A/C. If you can drop the inside temperature several degrees by running the vent fan(s) along with opening a window for a few minutes, you'll allow the A/C unit to get a jump on cooling your rig.
Enjoy!
02-19-2017, 07:04 PM
I have a 2014 Wildwood and found the same thing when we first traveled in cold weather. I found it was only the AC fan, not the AC itself. Our digital thermostat has a setting that allows you to use the AC fan to help circulate the warm air. It didn't work well..Check your thermostat instructions and it should explain how to disable the AC fan.
02-19-2017, 08:13 PM
on_the_bayou
The previous answers about the thermostat settings are correct but; This past week (Wednesday) there was a lighting strike near my RV, This caused the AC and the heater to come on. The thermostat was indicating an E4 error. I could not change any settings or even set it to off. The only way to stop the AC was to unplug from shore power. The only way to stop the heater was to turn off the propane. I disconnected the battery to stop the thermostat. When I reconnected the battery, the error code was gone. I set the thermostat to Off and then plugged in shore power. The AC came on immediately. I opened up the propane tank and the heater came on again about 15 seconds later. Remember I had left the thermostat in the Off position. It still remained in the off position. I used the thermostat and moved to AC and set the temperature that should have shut down the AC. I had to unplug shore power and turn off the propane again. The E4 error indicates an open circuit. The RV in in the shop awaiting repair.
2012 Crusader 290RLT
2012 Silverado 2500 Duramax (175,000 mi)
Camping:
2012: 4564 mi 31 days - 2013: 6277 mi 38 days
2014: 5146 mi 38 days - 2015: 1200 mi 9 days
2016: 342 mi 2 days - 2017: 2734 mi 22 days
02-19-2017, 09:18 PM
to primetime: I have to ask. did you have a electrical surge suppressor installed on the shore power? or did the lightning actually hit the trailer?
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
02-19-2017, 09:37 PM
on_the_bayou
No surge suppressor. Lighting strike was close. The TV in the RV was knocked out. The DriecTV box and sound bar power connector in my cabin.
Camping:
02-20-2017, 06:47 PM
I had the same question. Very helpful forum.
2017 Columbus Palomino F366RL
2016 GMC Duramax 2500 HD, PPEI Tuned, B&W Hitch
02-21-2017, 10:05 AM
Nothing like surge protection for these events
2017 Leprechaun 311 FS
Jeep Patriot and Cherokee as toad.
Enjoying retirement.
02-21-2017, 10:10 AM
Also if your furnace temp is to close to your AC temp setting both can be on at the same time.
