Old 06-09-2013, 02:11 PM   #11
Originally Posted by BigTJohn View Post
I think if you are a 30 amp site, with the adapter needed to connect your 50 amp main cord there will not be power - as in a dead feed for the second A/C unit. Without two 50 amp feeds for the 2 50 amp breakers, half of the cord will be dead. You will only have a single feed from the 30 amp box 1 hot, 1 neutral, one ground (3) wires. In the 50 amp, you have 2 50 amp hot, one neutral and one ground (4) wires.
Big, if he made his own adapter that might be true, but the ones you buy at the store power both 50-amp hots off of the 30-amp hot. Why would you want it any other way?!? You still have only 30 amps to work with of course.
Old 06-09-2013, 03:43 PM   #12
Fulltime family RVer
Barry's right. My 50-to-30 powers both sides of my 50 amp service.
Old 06-10-2013, 07:00 AM   #13
BigTJohn's Avatar
Yep, absolutely correct. I must have been thinking of 30 amp only and some how got off onto who knows what. However, running two A/Cs will be problematical. Use BR at night LR during the will work.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
