Originally Posted by burntcore
Ah, such great ideas! I never knew shower shields existed!
Question on the plexi... in the picture it appears that you screwed it first into the vanity then caulked the seams?
Yes. I attached to the vanity with SS screws and put a small piece of 1/2" wood behind each screw for the screws to bite into. If I were to do it again, I would have cut it so it went down the side, too. Then caulk.
I can't take credit for this one. It's a pretty common mod here on the forum.
Also, if you have the big white "rivets" holding your shower stall walls to the TT walls and if they're in the way of the shower shield, you can get auto panel retainers at any auto parts store. The nicest I found had some kind of tie-down thing on top that I had to cut off, but they worked very well. Just cut the offending ones off with a single edged razor blade, drill a new hole to the side and push in the retainer.
2011 Traverse LT, 3.6L, FWD
