Old 05-09-2012, 03:18 PM   #1
AFT # 2 Grey Water Pull Handle Broke
My 31 RETS-06 Aft #2 grey water shut off valve handle broke off at about the point where it pivots at maybe 40 degrees or so. It is made of hollow metal and not designed for old men like me. I'm thinking I can repair this but before I start I'm hoping for some guidance regarding the scope of the job. It doesn't look complicated but may involve removing a lot of skirting. My coach is still under warranty but I don't think it may be worth the $60.00 cost of diesel X two. I'm also thinking there should be a better mousetrap for this issue. Maybe Sabre Sam can chime in with an improved replacement to help me out. Thanks to all.
Steve
spat61 is offline   Reply With Quote
Old 05-09-2012, 04:58 PM   #2
Need pictures before anyone can offer suggestions.
Old 05-09-2012, 07:10 PM   #3
H2oski
When you get in there PLEASE post pics so I'll know what to do when mine breaks. Thanks ahead of time.
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
h20ski is offline   Reply With Quote
Old 05-09-2012, 07:33 PM   #4
Herk7769's Avatar
What you can expect when you get in there.
ID:	13489   Click image for larger version
Name:	Horst Probe Install 010.jpg
HAM CALLSIGN - KC3FFW
Old 05-10-2012, 10:44 AM   #5
Here to Help
Steve
I'm guessing without a picture. You might be able to just replace the rod. Not sure, a picture would really help.
SabreSam is offline   Reply With Quote
Old 05-10-2012, 10:45 AM   #6
Here to Help
Just so everyone is clear, these pictures are not from the Sabre Plant!
Old 05-19-2012, 08:25 AM   #7
For Sabre Sam
I'm hoping you can get an idea from production regarding the amount of disassembly I would need to do to repair this broken handle. The pictures posted above don't resemble my 31RETS. If you have a 31RETS-6 on the line, it should be easy to determine how far into this I need to go. Although I'm still under warranty, I will do it myself rather than take it to him. He is the type that infers the customer is the cause of the problem as opposed to inadequate materials and workmanship. All I did was push the handle in to close the valve and the fact that the handle is at an angle, and made of hollow rod, it just caracked at the point of the angle. Can you help? Thanks.
Steve
Old 05-23-2012, 07:54 PM   #8
No help with this problem
Steve
All I'm asking is if I should anticipate an hour job or an all day job, and an idea of how deep I will need to go into the bowels of the underbelly to get at the valve. Also, will I need to fabricate an upgrade handle rod to replace the existing hollow metal rod that broke at the angle point. No response from Sabre Sam?
Old 05-23-2012, 08:08 PM   #9
Herk7769's Avatar
Just my opinion here; but since you are under warranty, I am SURE that Sam will not be replying to your problem.
He has made it very clear in the past that he will help if he can.
If it is under warranty; he can't by contract with the dealers.
If you don't like your dealer, you can contact FR for an FR dealer in your area who would agree to handle your warranty work. It does not have to be a dealer who carries your exact model. (IE you might be able to get a Flagstaff dealer to do warranty work on your Rockwood).
Old 05-23-2012, 08:26 PM   #10
TURBS's Avatar
id put one of these on myself .
http://www.rveparts.com/product_imag...es/e1003vp.jpg
Old 05-25-2012, 07:01 AM   #11
Here to Help
Dear Customer,
It's very difficult to give you and advice without a picture of the problem. I don't want to misguide you in the time it might take to repair your problem. I do suggest that if you unit is under warranty, to have a dealer do the repair. But if not, I would drop a section of your underbelly, maybe only one side, to expose the valve. This would allow you to see how it's glued into the tank. But if the rod snapped and there is still a piece in the valve, you should be able to unscrew the piece and replace with a new rod. Any pictures would help so I could get you some more help.
Old 06-04-2012, 08:44 AM   #12
rve web site sewage valve handle
Originally Posted by f1100turbo View Post
f11turbo;
I think you hit on a good thing but can you elaborate on that part. I can't find it on the rveparts web site. Thanks. Steve
Old 06-04-2012, 09:15 AM   #13
H2oski
spat61 this is what turbo was talking about.
Electric Waste Valve - Valterra E1003VP - Drain & Flush Systems - Camping World
Wife
2012 Sabre 31RETS
(LA) Lower Alabama
Old 01-05-2014, 09:41 PM   #14
Peytonlover_18's Avatar
Has anyone I installed one of these themselves? My cable system broke on my Grey tank and I'm thinking of replacing with one of these myself. Any tips on installation? Thank you for any advice.
Sent from my SCH-I545 using Forest River Forums mobile app
Peytonlover_18 is offline   Reply With Quote
led pad
