Old 09-22-2016, 06:01 AM   #1
monde48's Avatar
Air-conditioning
Air-conditioning
I hope this is not a stupid question but I'm wondering if there's any way at all to quiet the air-conditioners in fifth wheel we have one in the bedroom and one in the living room this this is our first trailer we have ever owned that has two and the one in the bedroom really really noisy when you are trying to sleep
I'm just wondering thanks for any help
monde48 is offline   Reply With Quote
Old 09-22-2016, 06:15 AM   #2
First...the bad news. You are sleeping about 3 feet from the entire air conditioner. At your S&B home, the noisiest part of your air conditioner is behind your home where you can't hear it. So, the AC is going to be noisy and there is usually not much you can do about it. Some units needed different mounts for the air compressor and you could check to see if there is a recall on your unit.
Now, the good news...you'll get used to it! We did. Enjoy!
2012 CC 36CKTS Touring Edition
2015 Ford F-350 CC DRW Lariat
Joe_GA is offline   Reply With Quote
Old 09-22-2016, 09:37 PM   #3
amxpress's Avatar
Don't know what trailer you have or what year, but our front Dometic A/C in our 2013 Columbus was noisy and Dometic sent me a kit consisting of Some rubber bushings, a bracket, and a different designed compressor motor designed to reduce the noise and vibration. It helped a lot, but it still takes some getting use to as it is a few feet from you when you're in bed, as already mentioned.
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline   Reply With Quote
Old 09-23-2016, 05:49 AM   #4
monde48's Avatar
I want to thank everyone for their reply and I think what we will do is when we are in bed sleeping we will leave the bedroom air-conditioner off every simple solution
from what I have been reading that's what other people do once again thank you
Old 09-24-2016, 09:34 AM   #5
Yes, what we do is to lower the temp in the living room enough that makes the bedroom one not much needed. This works well after midnight
2017 Leprechaun 311 FS
Jeep Patriot and Cherokee as toad.
Enjoying retirement.
jonwisconsin is offline   Reply With Quote
Old 10-01-2016, 09:03 AM   #6
tugboat369's Avatar
I set the bedroom 2 degrees warmer then the living room so at night the AC in the bedroom dose not come on much if at all at night but stay comfy.
Camping from 2008, Life member Good Sam / KOA / iRV2
2014 Columbus 320RS
2011 Ford, F250, 6.7D, SRW
tugboat369 is offline   Reply With Quote
