Old 06-18-2012, 08:25 AM   #11
MEMBER
Thanks for the replies. Know Columbus and Sabre are using this tire. Trying to decide if I should use them for awhile, or go ahead and put Maxxis on it now. Have used Maxxis before with good results.
Banjer is offline   Reply With Quote
Old 06-26-2012, 12:04 AM   #12
I have them on my 32 RCTS. No problems yet. I can't explain it but I don't like the look of the tread. Are you concerned about catastrophic tire failure, short wear life span, quality of ride, etc?? a
Cathy & Jeff
Midland, Michigan
2013 Sabre 32RCTS / 2012 Ram2500 Hemi
On Order: 2020 Cedar Creek 34IK/2019 Ram3500 CID
SimchaSabre is offline   Reply With Quote
Old 06-26-2012, 09:18 PM   #13
MEMBER
Concerned about quality of tire and having tire failure. Going tomorrow and having 4 new Maxxis installed.
Old 08-08-2013, 07:26 PM   #14
How are the new tires working for ya? What are the specs on the tires? How much we're they? I want to replace my 235-80-16 on my 385BHS...
2013 Columbus Palamino 385BH
krisbarger is offline   Reply With Quote
Old 08-08-2013, 08:12 PM   #15
MEMBER
No problems with 4500 miles on tires. Maxxis M8008, ST235/80R16, load
range E, 3420# at 80psi. Bought locally $800.00 out the door, 4 tires mounted
and balanced.
Old 08-09-2013, 06:43 AM   #16
Trailer Trash
1% of Columbus owners have complained of Akuret tire failures. That would be 2 in 200 Columbus RVs for those keeping score. A couple of threads on Akuret tires here on FRF.
For those 1% club members, they have no idea why tire failed. Although overweight and underinflated was not an issue before failure. Leads me to believe failure was from road hazard, a fluke bad tire from Akuret, or misaligned wheel hub mounted to axle.
Dang near everything you buy at Walmart is made in China. Yes it's cheap stuff but when you think back, how much of it failed and died early? Made in China = super inexpensive labor force and manufacturing costs. Not necessarily poor product.
joelek is offline   Reply With Quote
Old 09-09-2013, 10:59 AM   #17
Akuret Tire
We had a Akuret ST235/80R16E fail with less than 4,000 miles on it. We are not overloaded. We have a 40 foot Columbus 365 RL 5th wheel that has a 3600 pound additional capacity and I am sure we are at less than 1/2 of that. I am fanatical about tire pressure checking before we leave on each trip. The other three tires were at perfect tire pressure. The dealer that I purchased a replacement from advised me that they had only one left and that the tire was discontinued. Other comments below say only one in 200 failure rate. What is the percentage that never get reported but just replaced?
My feeing is Akuret had a problem and discontinued the tire.
wheelmangg is offline   Reply With Quote
Old 09-13-2013, 09:12 PM   #18
lgray's Avatar
The Akuret Gamble
I have to agree with the doubt expressed related to the failure rate and reporting. I had two blow outs, over a span of three trips. Trust me, tire pressure, speed and load were not an issue. My rig (Columbus 320) has been in the shop for 10 weeks now, for $3,000 in damage from the last blow out. When I pick it up, it is going straight to the tire store for two new Maxxis, replacing the two remaining Akuret's. In addition, I purchased a TST tire monitor system to let me know of any rise in tire temp. or pressure increase/decrease.
If you have ever experienced one tire blowing out, not fun...if two on the same side were to ever go, could be catastrophic.
In my opinion, gambling on having "good Akuret's" is not worth the risk.
lgray is offline   Reply With Quote
Old 09-13-2013, 09:58 PM   #19
Denver, CO
garbonz's Avatar
keeping an eye on mine but good so far. had a 800 mile RT in June and will be going a couple thousand in a couple weeks, Have a TPMS and they are WAY underloaded so I am optimistic. 16 in LR E tires so they are pretty stout. for a 10K rig.
fingers crossed woo hoo
2017 Fuse 23T
Old 09-13-2013, 10:04 PM   #20
ryand's Avatar
Went to the Fall RV show here in St. Louis last weekend as our camping trip was cut short due to a hub giving out....I noticed Coachmen (FR brand) had a new tire I have never heard of on the 2014 units....I dont exactly remember the name but I do know they were still made in China. I wonder if its the same across the board for FR?
2011 Coachmen Catalina 28DDS
2015 Ram Bighorn 2500 6.4L
http://www.ryandethrow.wordpress.com
Nights Camped 2016: 32
ryand is offline   Reply With Quote
