Old 09-27-2018, 06:47 PM   #1
Duramax2017's Avatar
Andersen Hitch
Does any one have the Andersen Ultimate 5th Wheel Connection Hitch for there 5th wheel ? if so any comments on it
Duramax2017 is offline   Reply With Quote
Old 09-27-2018, 07:08 PM   #2
I've been using it for over 4 years now and truly love how it performs. At 35#, 4500 hitch weight, and 24K tow it has great capacity. It can be stored in the camper storage area without any problems. It feels like an articulating machine and seems to lock the camper to the tow vehicle solid. I've used it in a Tundra, 2500 Duramax and now on my 3500 Duramax and on 3 different campers. Rock solid experience and very pleased with the performance. Ironically note that I changed tow vehicles and campers but am still using the same Andersen Ultimate. HooRa because this is by far the best most useful purchase I have made since starting this exciting venture.
Do a search on the Andersen on this forum and you'll be reading for quite awhile.
Note: You cannot use this hitch with any swing style pinbox.
Make sure you purchase a torque wrench and follow instructions for tightening. I have found that doing an initial tightening without the trailer then connecting, loosening and retightening to correct ft. lbs. works well and ensures your connection is tight to the bed when the trailer is sitting on the Andersen.
2018 Cedar Creek Silverback 29IK
18 Silverado 3500 HD Dually 6.6 Duramax 4X4
Ultimate Aluminum 5th Wheel Hitch, TST tire monitors w/repeater
Semi-Retired February 3, 2014
Bob & Cindy
Lvn2tvl is offline   Reply With Quote
Old 09-27-2018, 07:20 PM   #3
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
I had one for 5 years to tow trailers between 18,000lbs and 21,000lbs and have nothing negative to report. My favorite was probably the vertically adjustable ball, some owners complain about the rather large footprint compared to the B&W hitch but I thinks that's overrated as there is room to slide stuff under and through the hitch frame.
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 09-27-2018, 08:16 PM   #4
Had one for two years now... love it.
Okie Dokie 2 is offline   Reply With Quote
Old 09-28-2018, 01:28 PM   #5
Head Rambler
X4! Had a Curt 16k roller for a little while and that thing was so heavy the it never got removed. It was a pain and always in the way. It takes me about 5 minutes total to remove the Andersen and I can pick it up with one hand and tote it around.
As said above, it's also rock solid when towing.
Gotta go campin!
Old 09-28-2018, 01:39 PM   #6
Mr. Dan's Avatar
There are several threads on this hitch. See this one (and it points to another):
Andersen Ultimate Connection 5th Wheel Trailer Hitch System with Adapter -
... and another: Andersen Hitches
Do a search for "ultimate" and you'll get several (plus other unrelated threads but you can process through them).
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 55; booked = 20
Old 09-28-2018, 01:45 PM   #7
Had one for a year. Like it a lot. I do not know a difference.
Personnel at the company are very service orientated.
We aare using it with a short bed Ram. Plenty of turning ability.
tomkatb is offline   Reply With Quote
Old 09-28-2018, 02:14 PM   #8
I have one I use with my Cedar Creek 29. My son tows his Big Horn 35 with one and my Son-in-law tows a 45ft XLR with one. No problems, easy to use, easy to adjust, and easy to carry!
rocco52 is offline   Reply With Quote
Old 09-28-2018, 03:39 PM   #9
A fellow camper here on the forum has a web page and he has done a comparison of the Anderson to the B & W Companion.
Learn To RV | All Things RV
merrykalia is offline   Reply With Quote
Old 09-30-2018, 05:17 PM   #10
This is what my Andersen Hitch did to my truck bed Click image for larger version
