Old 07-19-2013, 04:58 PM   #11
Herk7769's Avatar
Originally Posted by BMWPilot View Post
Correct. I did not use the USB drive to play the media file. I used a digital Media Player with HDMI out to the TV and the Optical to the 3.0
I don't understand it then. Does the Media player have an optical out?
You need to eliminate the TV as the source of the problem.
Dust in the optical port(s) can cause problems too.
HAM CALLSIGN - KC3FFW
Old 07-19-2013, 08:11 PM   #12
Smile
Originally Posted by herk7769 View Post
Per the instructions the USB drive is only good for VERY small video files (much over 50K bandwidth will get bogged down)so in effect won't handle full length "movies" AT ALL. It is for showing thumb drive photos and does a pretty good job at that. It will play MP3 files, too.
Page 9 of the owners manual states 8 gb's for the USB and 8 gb's for the SD card. Each must be formatted in FAT or FAT32.
l001952119 is offline   Reply With Quote
Old 07-19-2013, 08:31 PM   #13
Yes the media player has an optical output. This eliminated the TV as the source of the problem. Both the TV and the media player had noise through the GT 3.0 when using the optical connection for audio.
The problem will be getting the dealer to understand the issue to initiate any warranty repairs.
2013 Rockwood 8329ss
2006 Dodge Ram 1500 Quad Cab SLT 4x2 5.7L
BMWPilot is offline   Reply With Quote
Old 07-19-2013, 08:36 PM   #14
Herk7769's Avatar
I agree. Once you isolate to the radio, then the dealer warranty department should take responsibility.
Old 07-20-2013, 08:45 AM   #15
Remove Genesis
Can anyone tell me how to remove the Genesis from the cabinet. Looks like there is a removable bezel around the unit. Am I guessing correctly you pop off the bezel and there are some mounting screws under it?
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 07-20-2013, 09:10 AM   #16
Fulltime family RVer
You're exactly right.
Old 07-20-2013, 11:01 AM   #17
Herk7769's Avatar
There are two screwdriver slots under the lower edge. Insert a common screwdriver blade and twist EACH ONE before attempting to remove the bezel.
This should pop the lower edge free and then (and only then) pull the lower edge to you slightly and lift straight up. Using any other method to remove the bezel will break it.
The 4 mounting screws will be revealed.
