Old 07-18-2013, 02:59 PM   #1
Another Genesis question
Finally picked up my Sabre 32 RCTS yesterday. It was fairly clean of issues although there were and are a few. I will write in detail what we found so other buyesr can take advantage of that info.
My current issue was found while performing a through check out of the rig. On the Genysis 3.0 it seems that even though some of the speaker switches may be in the off position there is still some sound coming from them. For instance if I am playing a CD through speaker set "A" in the kitchen area and "B" & "C" are off you can still hear (and you can also feel the speaker vibrate if you touch it) what is playing through the "A" speakers. It is at a lower volume, almost like cross over but I would definitely not be playing any music inside during quiet hours as my neighbors would surely complain about hearing it. My dealer is going to replace the radio after we make a shakedown cruise but I am wondering:
1) Has anyone noticed this, you might want to take the time to check it out (remember the TV usually does not play through the unit. Try a CD)
2) I am wonder if it is an inherent design issue (That's bad)
3) I really hope Sabre used the correct speaker wire (gauge, shielding, etc) and I am not getting cross over. That would seem to be impossible to fix.
Any input is appreciated. The rig really is beautiful.
Davidceder is offline   Reply With Quote
Old 07-18-2013, 04:59 PM   #2
Smile
David: The only negative experience I am having with the Genesis 3.0 is the SD/USB slots do not display their information on the TV screen. We are currently awaiting the third radio for warranty replacement. One additional issue is the TV does not appear to play sound over the ceiling speakers. Still think the latter may be a wiring issue, but have not confirmed. I am NOT experiencing the sound bleed over on the two adjacent speaker lines. Keep us posted on your progress please. Thanks!
l001952119 is offline   Reply With Quote
Old 07-18-2013, 05:03 PM   #3
Herk7769's Avatar
Been my experience that un-shielded wire was used to run the speakers. In fact it is the same wire used to run the trailer lights as I am finding out.
HAM CALLSIGN - KC3FFW
Old 07-18-2013, 06:55 PM   #4
Other news
Spoke to Tech Support at Genesis. Was told there should be no bleed through. It might be a defective unit or the polarity of the speakers might be wrong. Seems to me getting the polarity wrong on 9 speakers is sort of doubtful. Since I just got my unit have not been able to investigate but should be easy enough to take a look at the wire and see what is up and what type of wire they used.
About seeing the SD/USB slots on the TV, I didn't even know you could do that. Will be interesting to play with.
About getting the TV sound through the surround sound. Many have complained about this but I have not seen a fix. You would need to take audio out from the TV and into the Genisis or the TV input into the Genisis and video back out to the TV. A good quality sound bar might be the answer. For DVD I would hook up an HDMI cable, might get a better picture. This isn't rocket science. We do all this in our homes all the time......
As far as I am concerned my system is inoperable the way it is and I plan on making every attempt to get FR to fix. What good is a system that plays through all speakers all the time.
Good luck guys, please post any solutions. By the way I downloaded a 37 page manual for the system. Said it was for a Heartland RV but there cannot be much, if any difference. If anyone wants a copy let me know and I can PM you.
Old 07-18-2013, 09:28 PM   #5
Herk7769's Avatar
There is an HDMI out only in the rear of the Genesis 3.
To get audio into the Genesis 3 there are input pigtails in the rear as well.
There is an optical input as well as a coax audio input (depending on your TV's audio output scheme). Yes you will need to buy and run these connections (comes stock set up for composite with stereo).
Using the HDMI will get you a high def DVD signal (720p) to your TV and the optical will get you surround sound from broadcast if your TV supports it.
Name:	ZX-800 connections.jpg
Old 07-19-2013, 05:48 AM   #6
Optical Input
I hooked the TV up to the Genesis 3.0 via the Optical input and it sounds worse than the stereo analog input. I hear hiss and other electrical noise and have tried to determine where it is coming from. It happens when connecting the optical to the tv or even a media player. Even with all lights and other electrical equipment off the noise persists. I have a message into Bob Fields and he is checking with tech support at this time.
2013 Rockwood 8329ss
2006 Dodge Ram 1500 Quad Cab SLT 4x2 5.7L
BMWPilot is offline   Reply With Quote
Old 07-19-2013, 06:25 AM   #7
Herk7769's Avatar
Wow, you would think the optical connection would be pretty clear.
I see a TV/radio fight brewing. They are gonna ask you to try a different optical audio source for sure (maybe a different cable too).
Old 07-19-2013, 09:51 AM   #8
I would agree with you if I had only tried using the cheap factory supplied 32" TV as the source However in trying to determine where the problem lies I tried a different optical source. I first used the Television where I got whining and hiss and then I used a media player that I use to play movies from my media collecation and I got hiss and data pops when the unit would read from the USB drive.
The optical cable is fiber so either it will work or not work.
Old 07-19-2013, 02:59 PM   #9
Herk7769's Avatar
I first used the Television where I got whining and hiss and then I used a media player that I use to play movies from my media collection and I got hiss and data pops when the unit would read from the USB drive.
Per the instructions the USB drive is only good for VERY small video files (much over 50K bandwidth will get bogged down)so in effect won't handle full length "movies" AT ALL. It is for showing thumb drive photos and does a pretty good job at that. It will play MP3 files, too.
Old 07-19-2013, 04:51 PM   #10
Correct. I did not use the USB drive to play the media file. I used a digital Media Player with HDMI out to the TV and the Optical to the 3.0
