07-12-2014, 06:32 PM
Another tire problem, almost
Inspecting our sabre today in prep for next weekends trip, about 160 miles each way, and I find the right rear tire looks like this? All others have even wear. Best I can tell, all pressures are right at 80psi as stamped. I'm not overloaded, in fact under by about 900lbs at heaviest I've ever been. Thoughts?
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
07-12-2014, 06:38 PM
Sorry to see that, you are lucky it didn't completely disintegrate.
It's a factory tire which should have been left at the Goodyear or Maxxis dealer.
07-12-2014, 06:58 PM
I'd change it, 160 each way is probably to much to expect. lol
Anyway I'm surprised you have no damage losing that much tread, how many miles did you get from that one?
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
07-12-2014, 07:39 PM
Only towed less then 500 miles this year and around 2000 last year. I'm going to get the spare out and see if it's the same make. I'll keep a close eye on them all but would like to wait a month before dropping the $$$. But, I also realize that could cost more. Last pull was just 7 blocks to our town park. Before that, 20 miles home from the sabre sitting at our local church camp for 5 weeks. I swear I checked with before that, but maybe missed this? Calling my tire dealer Monday I guess.
Joel and Teresa
2016 Sabre 34TBOK
07-12-2014, 07:51 PM
I would check to see if you have a bad or broken shackle on your springs or loose spring mount also I would check bearings for excessive play. One tire should not wear like that?
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
07-12-2014, 08:04 PM
Not much life left there but question remains.....what caused it? Axle bent? Lost balance? Love to hear if you find out.
2018 Forester 3011 DS
07-12-2014, 08:54 PM
This is sitting in my driveway and I kinda jackknifed it a bit more than usual as my yard was wet so I couldn't get straight.
Joel and Teresa
2016 Sabre 34TBOK
07-12-2014, 09:02 PM
Rear spring hanger looks to be slightly off vertical.
Another observation is the rear hanger is angled forward instead of standing vertical which is how we always set them when we built trailers. The way it is angled, when the spring is depressed, the shackle will travel back and raise the frame. Odd to my way of thinking.
07-12-2014, 09:56 PM
Thanks OC. I'll have my local shop look at it in my drive or take the whole rig to their shop. See what they say.
Joel and Teresa
2016 Sabre 34TBOK
07-12-2014, 10:05 PM
agreed
F-250 . stealth 3210 solar pannels, fantastic fans. and life line batteries
07-12-2014, 10:09 PM
Its probably going to be on the opposite side of the bad tire
07-12-2014, 10:24 PM
Everything looked fine there as well. I'll try and post a couple more pics tomorrow.
Joel and Teresa
2016 Sabre 34TBOK
07-13-2014, 03:51 AM
Do you think jackknifing the trailer into spots put enough side load on things to cause this issue....whats the date on the tires? Would a TPMS show higher heat on that tire than the rest? At least you caught it in time.....good luck
2011 Silverado 2500HD 6.0 Gas 3.73
2013 Flagstaff 8524 RLWS
1978 Cape Dory Ketch
07-15-2014, 04:28 PM
Not sure about tpms, and I don't think jackknifing is the cause. Tire shop said just bad tire and the belt let go.... New marathons going on tomorrow. $143/ea installed. Not the cheapest, but convenient and timely. It'll be Happy Campin! This weekend!!
Joel and Teresa
2016 Sabre 34TBOK
07-15-2014, 04:30 PM
Good choice.
07-15-2014, 05:58 PM
Had the same issue with our Sabre except both tires on outside tread on passenger side were wore. Had to get an alignment done. The toe was out on both. It was probably that way from factory but no way to prove that two years later.
07-16-2014, 06:33 PM
One belt was snapped for sure! I was very fortunate to have not had a blow out. Guess now I'm on the side of change them brand new factory tires out right away!
Joel and Teresa
2016 Sabre 34TBOK
07-16-2014, 07:16 PM
Ret E-9 Anchor-clanker
I wore the side by dragging (jack knifed). Only once will set the wear pattern on any tire..... for the life of the tire...
