Old 07-12-2014, 06:32 PM   #1
jtstromsburg's Avatar
Another tire problem, almost
Inspecting our sabre today in prep for next weekends trip, about 160 miles each way, and I find the right rear tire looks like this? All others have even wear. Best I can tell, all pressures are right at 80psi as stamped. I'm not overloaded, in fact under by about 900lbs at heaviest I've ever been. Thoughts?
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 07-12-2014, 06:38 PM   #2
Sorry to see that, you are lucky it didn't completely disintegrate.
It's a factory tire which should have been left at the Goodyear or Maxxis dealer.
Old 07-12-2014, 06:58 PM   #3
DDC
DDC's Avatar
I'd change it, 160 each way is probably to much to expect. lol
Anyway I'm surprised you have no damage losing that much tread, how many miles did you get from that one?
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 07-12-2014, 07:39 PM   #4
Only towed less then 500 miles this year and around 2000 last year. I'm going to get the spare out and see if it's the same make. I'll keep a close eye on them all but would like to wait a month before dropping the $$$. But, I also realize that could cost more. Last pull was just 7 blocks to our town park. Before that, 20 miles home from the sabre sitting at our local church camp for 5 weeks. I swear I checked with before that, but maybe missed this? Calling my tire dealer Monday I guess.
Joel and Teresa
2016 Sabre 34TBOK
Old 07-12-2014, 07:51 PM   #5
onetonford's Avatar
I would check to see if you have a bad or broken shackle on your springs or loose spring mount also I would check bearings for excessive play. One tire should not wear like that?
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 07-12-2014, 08:04 PM   #6
dcheatwood's Avatar
Not much life left there but question remains.....what caused it? Axle bent? Lost balance? Love to hear if you find out.
2018 Forester 3011 DS
Old 07-12-2014, 08:54 PM   #7
This is sitting in my driveway and I kinda jackknifed it a bit more than usual as my yard was wet so I couldn't get straight.
ID:	58043   Click image for larger version
Joel and Teresa
2016 Sabre 34TBOK
Old 07-12-2014, 09:02 PM   #8
Rear spring hanger looks to be slightly off vertical.
Another observation is the rear hanger is angled forward instead of standing vertical which is how we always set them when we built trailers. The way it is angled, when the spring is depressed, the shackle will travel back and raise the frame. Odd to my way of thinking.
Old 07-12-2014, 09:56 PM   #9
Thanks OC. I'll have my local shop look at it in my drive or take the whole rig to their shop. See what they say.
Joel and Teresa
2016 Sabre 34TBOK
Old 07-12-2014, 10:05 PM   #10
John McClain's Avatar
agreed
F-250 . stealth 3210 solar pannels, fantastic fans. and life line batteries
John McClain is offline   Reply With Quote
tire
