06-27-2013, 07:26 AM
#621
Camper Less Camping
Originally Posted by Ragin Cajun
I always use "slide lube", a spray on foam for rv rubber seals on slides...makes it slick & a lot less sticky, I apply to our campers about 4x/year...
Here's a pic!
2013 Sabre 32RCTS-6 (sold)
06-27-2013, 07:48 AM
#622
Always Learning
FYI
We're down in very humid FL @ the beach & we experienced condensation issue ourselves...what I found for a solution was keeping our bathroom vent closed & the fan off, as soon as I implemented with this...all vents went dry & air temp felt better in camper...
Interesting- this was actually our first few trips where we kept the bathroom vent open the whole time and the fan on intermittently to help dry towels. I never put the two together.
We were in PA and it was relatively light humidity. The humidity got worse as the weekend went on, but didn't get oppressive until Sunday as we were packing up. Heck, I jumped in the pool before we left to wash away some of the funk...
#623
Always Learning
Did I real that people are buying this from Walmart?
06-27-2013, 09:59 AM
#624
Camper Less Camping
I've seen both products on the shelf before there...I usually order off web with best pricing.
06-27-2013, 10:39 PM
#625
I too use a spray lube on the seals and one on the mechanisms. I've yet to do it on this unit, but perhaps I'll do it while we're out.
On another note, who has had the table base screws come out of the floor in the bunkhouse. Last weekend we had it happen, and all week I couldn't remember to ask on here, until now, now that we're back at the campground.
LINK TO MY MODS
2012 F350 King Ranch DRW 6.7L
2013 Sabre 36QBOK-7 Platinum Package
06-27-2013, 10:49 PM
#626
Always Learning
Not me, but we almost never use it.
06-27-2013, 11:02 PM
#627
We've not really used them either. Last weekend, the kids had lots of company, then I noticed 2 screws on the counter.....wife says she picked them up but didn't know where they came from......
I heard someone else had the screws back out/strip, I know they went with longer screws, I was just trying to see how much bigger/longer.
LINK TO MY MODS
06-27-2013, 11:12 PM
#628
We had the same issue the first night we stayed in our trailer. I thought we were gonna go crazy with the cycling. We talked to my dad the next day and he said that if you have 2 ac units in an RV you need to keep them a few degrees apart. We did that and the cycling problem went away. Hope that helps
2008 Ford F350 Diesel SRW
2014 Sabre QBOK-finally here!!
2004 Wildcat 29BHBP
1999 Sandpiper
Tent
06-28-2013, 12:58 PM
#629
Good point. Forgot that I did that after a couple days out. It did seem to help.
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
06-29-2013, 01:54 PM
#630
What is the weight capacity of the bike rack?
06-29-2013, 01:55 PM
#631
I believe 450lbs.
2014 Sabre 36QBOK
06-29-2013, 01:56 PM
#632
Originally Posted by brandon327
what is the weight capacity of the bike rack?
LINK TO MY MODS
06-29-2013, 02:01 PM
#633
Mine don't have the sticker on it.
Well if the bike rack can handle that, that means the rear of the frame can handle 450lbs. So if you were to install a swivel wheel cargo carrier you could have a max tongue weight of 450 lbs.
06-29-2013, 03:28 PM
#634
I believe sabre sam suggested awhile back that the frame warranty would absolutely be void if there was some towed behind a sabre.
Turbs
06-29-2013, 03:54 PM
#635
What is the frame warranty anyway? How long?
06-29-2013, 04:42 PM
#636
Same as your camper warranty.
One year unless you bought the extra year then 2 years.
Turbs
07-03-2013, 07:42 PM
#637
Maiden trip went great!! No problems at all. Need to verify the cable tv works but will do that at home. Campground had very bad signal. DH was happy with he towing and parking and set up was much easier than TT.
We have a real problem with getting the camper in our driveway. Very narrow street so backing in is tough. Took 2 hours to get it in the spot next to the house. Need a better plan or a storage place to keep it. Any suggestions?
2014 Palomino Sabre 36QBOK
2008 Ford F-350 4x4 Crew diesel
07-03-2013, 09:27 PM
#638
Always Learning
It gets better. My first time parking at the storage yard to 50 minutes for what should have been an easy park job! We're down to 5 minutes...
07-03-2013, 11:21 PM
#639
Yep... Lots of practice. Before you know it you will be backing it in like a pro.
2014 Sabre 36QBOK
07-16-2013, 05:41 AM
#640
Originally Posted by LaydBack
Bags will help the sag on the rear of the truck, but will only make you nose higher.
Well LaydBack, here we are 4 months later with some adjustments. Air Lift Bags and raised the pin box one hole. Handled good, some side gusts were noticed but very manageable. We traveled 550 miles in 94 degree air temp and 135 degree road temps and there were no noticeable difference in temp between front axle and rear axle tire temps. This set-up is as good as it gets, I have one more hole to raise pin box. BTW, the distance between top of bed rail and under the nose is still good at 7 ". Oh, and the other 'issue' I had before with the capture plate bolt breaking.....didn't, so I guess that make's this set-up a little more 'happy'.
2013 Palomino Sabre 36 QBOK-7
2012 Ford F-350 SRW 6.7 CrewCab ShortBed
PullRite SuperSlide 18k IS Rails
2006 HarleyDavidson RoadKing Classic
